Old 03-15-2016, 08:27 PM   #1
PIG-TECH
PIG-TECH's Avatar
exhaust cutout valve?
i am putting new headers and exhaust on my 72 C20. 402 big block. i am installing after market headers and with dual exhaust
first question: what are the pros and cons of using a exhaust cutout valve?
second if i do get a new one should i go factory or remote ?
here is a pick of the old one
PIG-TECH is offline   Reply With Quote
Old 03-15-2016, 09:47 PM   #2
CST10
CST10's Avatar
Re: exhaust cutout valve?
I would go remote as they limit the amount of torque put on the cutout when closing. I have ruined a few of them just holding the switch just a lil too long on closing.
MyToys:
Goldilocks the "Ol School Survivor" 1968 C10, SWB Stepside, 08/15 TOTM, 250 CI 6 cylinder, 3 on the tree, 3.73 rear, 3/5 static drop, 23,500 original miles.
Samson the 1970 CST10, LWB, 462Ci, Turbo 350 tranny, 3.08 rear gear, PB, PS, A/C, AM/FM, 2/4 Drop.
Brutus the 1998 Camaro Z28, 33,500 original miles, LS1, 519 RWHP/497 RWTQ.
Member of the Louisiana Classic Truck Club, LCTC
Member of the Louisiana C10 Club
Member of the Baton Rouge Drifters Car Club
CST10 is offline   Reply With Quote
Old 03-16-2016, 12:47 AM   #3
PeterHall
Friend ran a qtp cutout for around 2 years. Never had any issues with using a switch. I bought some cheap ones off ebay and we'll see how well it works.
PeterHall is offline   Reply With Quote
Old 03-16-2016, 12:48 AM   #4
Z10
Z10's Avatar
What you are showing is a heat riser valve. When the exhaust heats up the spring expands and opens the valve. This is not an exhaust cutout.
Here's a new one on eBay.
http://www.ebay.com/itm/Chevelle-Cam...tWJnCL&vxp=mtr
1969 RS/SS Z10 Camaro Pace coupe
1972 GMC Short Step buildhttp://67-72chevytrucks.com/vboard/s...=1#post6356218
1979 Mazda RX7
1979 Pontiac Trans Am WS6 & 1979 Pontiac Trans Am 10th Anniversary
1999 Honda Valkyrie
2006 Corvette Z06
2010 BMW 650i
Z10 is offline   Reply With Quote
Old 03-16-2016, 09:12 AM   #5
PIG-TECH
PIG-TECH's Avatar
thanks Z10.
Old 03-16-2016, 12:21 PM   #6
kwmech
Heat riser is an emission thing. Flap closed while engine cold. Exhaust would then be partially diverted up through the exhaust crossover in the intake manifold, thus heating up the intake faster for better fuel atomization. Once the engine warmed up to operating temp the flap would open. Why you want this on a header is up for question
Old 03-16-2016, 07:29 PM   #7
swamp rat
swamp rat's Avatar
Eliminate it..
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-16-2016, 08:54 PM   #8
PIG-TECH
PIG-TECH's Avatar
eliminated. thanks swamp rat.
Old 03-17-2016, 01:21 AM   #9
89AKurt
89AKurt's Avatar
Follow up question, since my truck doesn't have the emissions junk, has the ram horn manifold, Holly carb, and I want to redo the exhaust, removing this should be okay?
1968 Long Bed
2016 Honda Civic Coupe EX-T ticket magnet
89AKurt is offline   Reply With Quote
Old 03-17-2016, 06:50 AM   #10
Grumpy old man
Grumpy old man's Avatar
keep the rams horn manifolds and run new 2 1/4 inch exhaust back from them (assuming its a stockish small block )
1967 Factory short bed - Old school
'71 - 350 / 4bolt / 487 heads / Edelbrock C3BX
Muncie M-22 4 speed / Hurst Comp plus
Factory 12 bolt posi 3.73 / 255-70-15
Smoothed firewall / Factory cowl induction
Power disc brakes / power steering / 3.5-5" drop
Grumpy old man is offline   Reply With Quote
Old 03-17-2016, 11:42 AM   #11
burnin oil
He has a BB. I would follow his advice still unless those manifolds are horrible. I run headers only because that is what fits my heads (D ports). If you want some better flow look into Sanderson's as they are cast iron. This eliminates all the headaches of bad sealing, leaks, scratched coatings, or rusting out. My coated headers have a good amount of rust after 2 years and they are coated and had the proper break in procedure.
burnin oil is offline   Reply With Quote
