Old 03-15-2016, 09:33 PM   #1
Dan-o
292 ci. What valve springs?
Building a 292 for my 1966 c-10 I'm looking at running a mild cam. 213/213 duration at .050 with .502 lift on a 110 Lsa. I'm having trouble on finding information on what valve springs to run. I see 12bolt has a set. But just curious if there are other options.
Thanks in advance.
Dan-o is offline   Reply With Quote
Old 03-15-2016, 09:54 PM   #2
TJ's Chevy
TJ's Chevy's Avatar
Re: 292 ci. What valve springs?
Tom's set is pretty good. I don't remember what I used for mine. Running .499 lift on my 292.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 03-16-2016, 02:32 PM   #3
GRX
GRX's Avatar
Comp Cams 980-12 should get you there.
GRX is offline   Reply With Quote
Old 03-17-2016, 01:00 AM   #4
Heater63
Heater63's Avatar
Tom at 12bolt has done a whole lot of inline testing and work...I trust his opinion and a lot of my 292 blueprinting was based on his dyno testing in recent years. You need to look at things other than springs...Lumps in the intake ports?? valve sizes? cutting down for screw in rocker studs? roller rockers? custom pushrods??
Tom can help with all that, heck he can build your head for you.
For cams, if you haven't purchased, you might check out the dual phase cam that Schneider Racing Cams in Cali makes. Im running one.
292 + TKO500
Heater63 is offline   Reply With Quote
Old 03-17-2016, 01:22 PM   #5
Dan-o
Thanks for the info. I've got 99% of everything else figured out. I've got "the book" and have done a lot of research on this stuff. Just haven't been able to find a whole lot of info on the springs.
Cam is already on its way, I actually tried contacting Tom twice and never got a response so went with someone else.
I'm just wanting a good cruiser, setup is as follows
LP pistons .040, Offy 4 barrel intake. Demon 4 barrel carb with vacuum secondary's. long tube header. 1.94 intake valves. I opted out of doing the lump port. using the cam i inquired about above, ARP rod bolts, Arp main studs.
I've currently got a worn out 230ci in the truck with a supercharger running 6psi. cant wait for my 292 to be done!
Old 03-17-2016, 02:07 PM   #6
GRX
GRX's Avatar
Sounds like a nice set up.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
Old 03-17-2016, 02:14 PM   #7
Dan-o
I ended up ordering from 12bolt. Since it comes with everything it was just easier. plus I needed a cam thrust plate anyways. The springs are just something I'm not familiar with how to pick out. I would usually just by cam packages that come with matching springs, but that wasn't an option in this case.
Thanks for your input!
Old 03-17-2016, 02:29 PM   #8
GRX
GRX's Avatar
Should be good. The ones I recommended would still give you .050 or more between coils at the full .502 lift.
Old 03-17-2016, 03:22 PM   #9
TJ's Chevy
TJ's Chevy's Avatar
It'll make a nice engine for sure...and take on a 350 if ya want to. lol I did very similar with mine.
Ross 18 cc dish .040 pistons
Comp 268H 219 @ .050 .499 lift
Lump ports and 1.94 intake 1.60 exhaust valves
block 0 decked
clifford manifold and short tube headers.
I'm going with the 625 road demon. Is that the one your looking at?
Old 03-17-2016, 03:26 PM   #10
Dan-o
block 0 decked
Yeah 625 road demon is the exact carb I have. Picked it up used. rebuilt it. I'm unsure of jetting on it however. I plan to start with a 64 primary jet and 72 secondary and go from their.
Old 03-17-2016, 04:57 PM   #11
TJ's Chevy
TJ's Chevy's Avatar
Should work nicely. The new ones are supposed to be calibrated for the 6 cylinders. Expensive, but a darn good carb.
Old 03-17-2016, 05:08 PM   #12
Dan-o
Im not sure the exact date mine was manufactured but It looks very new, still has plenty of shine! I've got less than $300 in mine the way it sits. Rebuilt, including a plethora of jets. I couldn't pass it up.
Old 03-18-2016, 12:56 AM   #13
TJ's Chevy
TJ's Chevy's Avatar
Nice! Brand new they are now like $469. lol
Old 03-18-2016, 03:32 PM   #14
Heater63
Heater63's Avatar
Sounds like you are on track for a great engine! Very similar to mine. I am running an Edelbrock 500cfm on Offy, and very pleased so far.
make sure you have a good sealant and seating on your head studs. I had one leak a little coolant during break in and had to re-do it.
292 + TKO500
