03-16-2016, 12:24 PM | #1 |
wtb EFE Valve (Exhaust heat riser)
Just another poor CA soul trying to appease the smog overlords. I am in need of an EFE valve (Exhaust heat riser) for an 83 K3500 with 454. It mounts between your passenger exhaust manifold and the rest of the exhaust, and has a vacuum actuator on it. Most of you probably ditched it with the stock manifolds in favor of headers long ago.
It's worth $50 + Shipping to you, to hunt one down and send it to 93616. Let me know Zack
1967 CHEVELLE MALIBU 427/700R4 1971 CHEYENNE 10 350/350 1983 GMC K3500 454/400/205 1987 R10 TBI 350/700R4 2014 CRUZE 2.0 TURBO DIESEL |
03-17-2016, 02:35 PM | #2 |
Re: wtb EFE Valve (Exhaust heat riser)
I have one off of a 1980 350 but they are probably not the same. ???
03-17-2016, 07:19 PM | #3 |
Zack do you have a GM part number for it? If nothing else we can see what other models might work for you. I`m dealing with my own cali smog issues so I feel you. Those of us in smog jail need to stick together and keep these old girls running.
Anthony |
03-18-2016, 12:02 AM | #4 |
Should be GM# 1996643 which is discontinued but...... one from a few years newer should work. GM# 5234810 / AC Delco 214-510 is what I used to put on P chassis' with 454's and which should be available from Hamilton Manufacturing as part number HR810. This fit 350's with HD emissions (larger diameter opening on manifold) OR 454's. 305 EFE valve wont work as they used smaller diameter opening and smaller flange mounting bolt spacing.
You will also need to get a donut GM# 15592451 (this will be available from local auto parts store...) http://www.hamiltonmanufacturing.ca/hrv.htm http://www.autopartsobsolete.com/198...e-5234810.html http://www.ebay.com/itm/GM-5234810-A...tVFyPr&vxp=mtr Might also trying hitting up the junk yard. Doesn't need to work just as long as it is there and hooked up for the visual inspection.... Hope this helps. |
03-20-2016, 08:38 AM | #5 |
I have a brand new Hamilton/LMC 2-1/2 heat riser, I'll sell it at cost.
83 K30 SRW 350 TH400 NP205 4.10 9' Fisher 85 K30 SRW 350 TH400 NP205 4.10 87 V3500 Dually 454 TBI SM465 NP205 4.10 9' Fisher 83 K2500 350 TH700R4 8600GVW Dual Tank 4.10 1973 Cheyenne Super 30 DRW Std Cab Z83 4.10 1976 Silverado C30 Std Cab 4.10 DRW (4 sale) |
03-22-2016, 11:33 AM | #6 |
Thanks for all the replies, I actually found the original in a box of parts that came with the truck when I got it. One of the first bits of good luck on this truck so far. Hopefully its the start of a trend ha ha.
Special thanks for the part no. for the donut. Now I can give the clown at the parts store a number to reference so I don't get the same dumbfounded look when I ask for it. I tried yesterday. It resulted in me having to explain what an EFE is, which resulted in having to explain what a butterfly valve is. And then an explanation of actuators and a vacuum system. I got nowhere fast and remembered why I come on here to discuss how and why, and only should go the parts store with part numbers to reference.
