Old 03-16-2016, 07:48 PM   #1
Zach079xxx
Zach079xxx's Avatar
What is this connector?
I was cleaning my engine bay today getting all that nasty winter crap off of all my polished parts and found this. What is this connector for?
85' GMC Sierra Classic
Built 350; Weiand intake, Holley 600, Thumpr Cam
Built 350 turbo with shift kit & 2500 Stall
Thumpin' away
Zach079xxx is offline   Reply With Quote
Old 03-16-2016, 07:57 PM   #2
Jake Wade
Jake Wade's Avatar
Re: What is this connector?
Should be a mate to it coming off the distributor. Your distributor may have been swapped to the old style which does not have this so, someone left that hanging out.
Jake Wade is offline   Reply With Quote
Old 03-16-2016, 08:09 PM   #3
Zach079xxx
Zach079xxx's Avatar
As far as I know it had the original 85' HEI dizzy, then I had a guy replace it with a MSD HEI couple months back.. I wonder if it connects up to the MSD, I didn't see any other wire though, what's the function?
I should add, the truck originally had a 305, now has a 350
Thumpin' away
Old 03-16-2016, 08:42 PM   #4
Jake Wade
Jake Wade's Avatar
IF your current distributor does not have the mate to that plug coming out of it, a pre computer style distributor was installed. The computer has been bypassed for that part.
Old 03-16-2016, 08:44 PM   #5
Jake Wade
Jake Wade's Avatar
Personally, you/your motor are/is better off with what you got now, in my opinion.
Old 03-16-2016, 08:57 PM   #6
Mr.Chevy4x4
Mr.Chevy4x4's Avatar
It was for the ESC (electronic spark control) module that those trucks came with (plugged into the distributor). It retarded spark advance based on a knock sensor that was on the lower passenger side of the block.
All things Chevy truck:
1986 SWB "Jolene" boosted 5.3/4l80e project
Mr.Chevy4x4 is offline   Reply With Quote
Old 03-16-2016, 09:06 PM   #7
Zach079xxx
Zach079xxx's Avatar
Thanks guys. I knew that connector wasn't there until recently lol
Just kind of scared me seeing an unplugged wire!
Thumpin' away
Old 03-16-2016, 10:59 PM   #8
Pontiac1976
Pontiac1976's Avatar
GM set up a lot of trucks with both set up's for the DIST.. As my 84 has duel set ups parts truck that I got all the wiring w/fuse box & front clip off for my 77.
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
Old 03-16-2016, 11:11 PM   #9
Zach079xxx
Zach079xxx's Avatar
That would explain it. Thanks you guys! Today was a good day, I've been having a pretty serious oil leak everywhere I'd go I had a puddle of oil left behind, well today was nice weather and I actually had time to look into it. Climbed under the truck and saw oil down the side of the engine, popped the hood and I could tighten the last valve cover bolt with my finger, tightened that up and no more oil leak! Thank the lord, it was driving me insane recently.
Thumpin' away
