Firewall Insulation Pad
Anyone replace one? Any tips would be appreciated ..
1985 K20 4spd 1978 K20 4spd |
Diggin The SquareLife
Re: Firewall Insulation Pad
Most ppl dont run them from what i seen....u will see someone now an then with one
You have to have a lot of stuff out. Do you have a/c or not?
WO/AC is less work I still try to find a none /ac pad.
![]() Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change. |
Active Member
![]() Join Date: Nov 2014
To put it in correctly you have to have pretty much everything out from under the dash. I just tried putting one from LMC in my 83 with a/c and could not get it to fit right at all, I'll make you a good deal on it!! I ended up getting one from somewhere else and it worked good, I will post tomorrow where it came from, I can't think of it right now
I put a double layer of that foil insulation from Home Depot up there
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
Well that's kinda what I thought just glancing at it, lots of labor .. thanks, I think I'll look into alternatives.
What are your impressions of the foil?
Active Member
USA1 Industries Inc is were I ordered the insulation pad that fit really good
Do you if they sell none a/c pad
Active Member
I believe they do sell the non a/c pad
10-4
