Lil help with lugnuts plz
I bought a set of ion alloys for my 66....I understand the size is 7/16x20 but the lugs need to be like 1 3/4 er 2" deep? Not shank style they are acorn? I guess....the Dell's that sold me the wheels gimme his lugs ....the were deep enuff, but threads were too big....my question is what would I ask for when searchin? I find several 7/16x20 but not very deep?
Sorry if I sound unedgumacated!!! Lol |
Re: Lil help with lugnuts plz
PIC of the ones you have would help
Never Ending Projects
Not many options for deep 7/16" lug nuts. I think Crager sell some deeper ones but not sure if they will still be deep enough. http://www.summitracing.com/parts/cr...2b-4/overview/
You might have to go with open style lug nuts or cut your studs shorter.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
The longer ones came with the wheels....they're the size I need.....shorter ones were already on my truck
these are what you need i believe (bulge nuts) http://www.ebay.com/itm/24-Bulge-Aco...RWvQuf&vxp=mtr
#6 | |
For 7/16" threads, there are almost none out there. Every other size they seem to be available in the long lengths.
i agree back when i helped a old friend put on some mags we had to cut his wheel studs because even the the washers they came with were still to short
You might try these. http://www.ebay.com/itm/261511321397...%3AMEBIDX%3AIT They are deeper than the standard. 1.81 inches long
65 C10 Short bed, Fleetside, small back window Build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=619304 |
The problem is that when the lugs are threading......they sink in too far in the wheel....where a socket or 4 way has nothing to "grab" to tighten em...
Thanks all for the helpin...they gotta be out there........ |
Dunno if this pic helps....but the lug you see on there is only grabbin like 2 er 3 threads....then my socket won't grab end of lug....
![]() ![]() Join Date: Jul 2002
These are what I got for my 64.
![]() They are barely stick out on my Eagle Alloy's I also because of some damage, I had to replace a few wheel studs and used ones a hair longer. Dorman 7/16 x 20 Wheel Lugs (610-165)
I am a thinking they used to make a thin wall socket that would fit ?
If you don't like this ![]() |
#13 |
![]() Join Date: Oct 2012
That is what I had to do on some aluminum rims I had on a Dodge.
#14 |
I was thinking same thing? I seen these fluted type lugs that use a sleeve to take em on er off....any body using those types? Jus curious if they're any thinner? Can't find any one selling a single lug ta try.....
#15 |
I think I actually ended up using an impact socket. I just kept trying 3/4" deep sockets of various brands and kinds until I found one that would fit.
#16 |
Yep, I use a deep impact socket (Harbor Freight) for mine. It just clears everything.
#17 |
IF the nuts you have only grab by a few threads then you need something like these you might have to use a thin socket and NOT a 4way http://www.ebay.com/itm/24-ET-Style-...ZWeIOS&vxp=mtr
#18 |
60-66 Nut
![]() ![]() Join Date: Mar 2007
These are even longer than the ones Palf70Step posted.
![]() The ones jtrichard posted might help as well, just be sure they don't bottom out before the wheel is tight.
#19 |
how far is the lug stud sticking out of the wheel for the lug to screw onto?
1961 chevy K10 my build is------------61K10 build |
#20 |
I think those jus might be the ones!!!! I've orderd them... be here next thursday...will let y'all know!! Thanks to all SO MUCH!!!
#21 |
I would still recommend some fancy thin wall impact sockets. They would save you from scratching up those wheels. Gorilla makes sockets with a removable plastic sleeve just for wheels like yours. Summit carries them but you may be able to find them cheaper somewhere else.
http://www.summitracing.com/search/p...pact%20Sockets |
#22 |
You guys are awesome and most helpful😀😀😀😀 thanks a bunch!
#24 |
Did you use the ET style nuts?
#25 |
I got the ones captain fab posted....and gotta thinwall socket....
