Old 03-17-2016, 05:04 PM   #1
LilJohn72
LilJohn72's Avatar
Brake upgrade
Hey everyone, I'm not positive that this is the best place to post this or not but I've got a brake predicament. I've got a 72 lwb C10 with front disc brakes, as you would expect, and I use the truck at the drag strip pretty frequently, it is just for fun though it isn't very fast at all, it is my weekend driver, but I've run into the problem of my brakes not holding at the line. When I go to power brake it at the line they seem to slip. Does anyone have any suggestions about what I could do to fix this? Upgrade to an after market kit, replace shoes or rotors? Anything at all? That's for any advice you have!
LilJohn72 is offline   Reply With Quote
Old 03-17-2016, 05:06 PM   #2
LilJohn72
LilJohn72's Avatar
Re: Brake upgrade
Sorry I guess it would be brake pads not shoes.
Old 03-17-2016, 06:25 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Brake upgrade
Changing over to Wilwood D52s was nice for me. I'm on rear drum still and its just starting to become the weak link.
I also run hydroboost, which isn't needed, but is enjoyable.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 03-18-2016, 03:23 PM   #4
LilJohn72
LilJohn72's Avatar
Re: Brake upgrade
Is switching to the D52s good enough without switching out rotors?
Old 03-18-2016, 03:24 PM   #5
ranger danger
ranger danger's Avatar
Re: Brake upgrade
I'm in the process of converting to disc front on my 69' C20 Suburban. Im using all the parts from a 72'. I have not purchased the calipers yet. I was planning on getting a set of OE remans from Napa for about $40 each. The Wilwoods are about $400 retail. Are they really worth the difference in price?
1969 C20 Suburban "Rez Dog"
Rebuild America one testicle at a time.
US Army 1977-1979 12B Combat Engineer
US Navy 1979-1983 Gunners Mate Guns (GMG)
NRA Life Member
Unrestrained Children in back seats cause Accidents.
Unrestrained Accidents in back seats cause Children.
ranger danger is offline   Reply With Quote
Old 03-18-2016, 03:33 PM   #6
Valarius_Starchaser
Valarius_Starchaser's Avatar
Re: Brake upgrade
The dual piston setup of the wilwood D52s offers better pad contact area with such a large pad and a single piston the pad will "banana" or flex under hard braking and can prematurely bow out and cut your braking power in half very quickly.
In short the dual piston will reduce premature wear and stop faster/harder and should hold you at the line
Only other thing that's better is a line lock
"Orange Crush"
Valarius_Starchaser is offline   Reply With Quote
Old 03-18-2016, 03:37 PM   #7
ranger danger
Re: Brake upgrade
This is not a race truck but I do haul a RV trailer in the mountains on a fairly regular basis. I'm switching to disc because I get overheated drums and bad brake fade
NRA Life Member
Old 03-18-2016, 03:45 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: Brake upgrade
Line locks don't have a "release" force,so actually trying to leave off one will drag your brakes the first 20-30ft or so. Guys have tried using them as an alternative to the trans brake but it really isn't ideal. You can use it as an anti-lag for boosted cars much the same way, but it'll drag the pads no matter what.
Old 03-18-2016, 04:01 PM   #9
Custom 68
Custom 68's Avatar
Re: Brake upgrade
Welcome to the site. I too am from the Springfield area. We will need to meet up at the track sometime. It is a fun time.
I did swap to the Wilwood D52 swap on mine and the hydroboost. They look great and I am pleased with them. Currently I have a manual in my truck so not much power braking at the line for me. I will be swapping back to an automatic and then it might pose more of a problem. I used the disks I already was running as they were fairly new. I am using a Hawk pad. I don't remember which set.
good luck
Dave
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 03-19-2016, 03:53 PM   #10
Mike C
Mike C's Avatar
Re: Brake upgrade
Before you dump a ton of coin, look into some more aggressive brake pads that don't require a lot of heat to work.
It sounds like you don't have enough pressure on the front or at least enough grip. The factory brake setup is pretty powerful with all the right parts. Flush the system for some good high performance fluid and buy some good brake pads.
The rears do more work when towing, but they still are not responsible for the lions share which happens in the front.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 03-20-2016, 11:15 AM   #11
LilJohn72
LilJohn72's Avatar
Re: Brake upgrade
I definitely like the wilwood idea simply based off of looks, even though my wheels wouldn't show them off. But before I do go and dump that kind of money into it I do think I'll try out what Mike C said and throw on some new pads and flush the brake system to see what that gets me. And thanks for the welcome Dave, it's good to see other people on here from the Springfield area. Your 68 sounds awesome and I am all for meeting up at the track sometime although, it wouldn't be anywhere close to an even race.
Old 03-21-2016, 10:39 AM   #12
Custom 68
Custom 68's Avatar
Re: Brake upgrade
We just go put and have fun. There seems to always be somebody faster... I have a friend with a 68 Camaro and we go hit it on occasion. Its almost car show season so there will be more spots to stop and look. I will keep my eye out for yours and you do the same.
Dave
