Old 03-18-2016, 10:53 AM   #1
Coach529
Coach529's Avatar
Shocks on a bagged front end.......
Trying to get shocks figured out on my front end. It is Danforth crossmember with S-10 Donor parts.
Will this set up work, or do I need to get my shock closer to my ball joint?
1949 Chevy 3600
"Adventures of Henry"
http://smu.gs/QOlhWY
Coach529 is offline   Reply With Quote
Old 03-18-2016, 11:20 AM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Shocks on a bagged front end.......
With the shock mounted to the lower arm that close to the pivot point, it will do almost nothing. You will want it at least to the mid point of the arm.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-18-2016, 01:35 PM   #3
dubds10
Stalker Nate
Exactly.
1957 GMC SWB stepper modified summer time driver
1963 Chevy Fire Dept. Command Center Van 2 ton - future food vending truck project
1965 Chevy P10 Ice Cream Truck project
Instagram - TheDonutDiner
FaceBook - @UscreamIscream
dubds10 is offline   Reply With Quote
Old 03-19-2016, 10:36 AM   #4
Coach529
Coach529's Avatar
Thanks guys. I will reconfigure it.
1949 Chevy 3600
Old 03-20-2016, 05:09 AM   #5
andrewmp6
Mount your spindle and wheel and turn the wheel so you can see just how much room you got to work with.The other option is start all over with a shockwave which is a air bag and shock combo.
andrewmp6 is offline   Reply With Quote
Old 03-31-2016, 10:57 PM   #6
chase@ridetech
chase@ridetech's Avatar
I would try to get at least in this area
Chase Mundy
Direct Line: (812) 481-4736
Email: chase@ridetech.com
chase@ridetech is offline   Reply With Quote
Old 04-04-2016, 06:21 PM   #7
Coach529
Coach529's Avatar
with tires clearance and over the frame headers I am pretty limited on space.
Does any body ever stick the shocks on the front's of the LCA's?
1949 Chevy 3600
Old 04-05-2016, 11:04 AM   #8
chevy_mike
chevy_mike's Avatar
If it's a front steer setup, I think you will run into clearance issues with the steering linkage.
Old 04-05-2016, 11:11 AM   #9
Coach529
Coach529's Avatar
There is a little room there, but it does get tight.
1949 Chevy 3600
Old 04-08-2016, 02:34 AM   #10
andrewmp6
As long as nothing is touching i would run it like that.
Old 04-08-2016, 12:40 PM   #11
chevy_mike
chevy_mike's Avatar
Agreed. If you can cycle and turn the wheel in all directions and you keep a 1/4" minimum clearance, you should be fine.
