03-18-2016, 12:19 PM | #1 |
87 TBI 350 runs rich, stalls, stumbles, slight backfire out exhaust
I recently did my ECT sensor, MAP sensor, checked for vacuum leaks. Checked fuel injectors and they seem to be working well (no leaks or off spray patterns. Currently have no codes popping. If snap my throttle in park, it will act like its ran out of gas for about two seconds and then rev. If I then quickly let go of the throttle it'll pop (very slight backfire) from the exhaust. Truck never fails to start nor does cranking time fluctuate, so I'm pretty confident it's not fuel related. If I drive it under very light throttle it will stall, especially if I let off. I've read O2 sensors can definitely cause these problems but EGR sounds most likely. I'll probably pick up an EGR from Autozone or Napa today. I may do the O2 as well, but i want to look into upgrading to a heated sensor.
Has anyone experienced similar troubles with their TBI 350? Thanks guys! |
03-18-2016, 12:32 PM | #2 |
Re: 87 TBI 350 runs rich, stalls, stumbles, slight backfire out exhaust
have you tried cap/rotor/plugs/wires???
Allengator Outta the Blue (my band - available for hire in the DFW area!) 1980 Chevy SWB Pickup (build thread) 1951 Chevy Sedan Delivery 2004 Chevy Tahoe Z71 2011 Harley Davidson Street Glide 2018 Silverado Z71 Crew Cab |
03-18-2016, 12:44 PM | #3 |
Does the truck have any codes?
Anthony |
03-18-2016, 03:21 PM | #4 |
I had issues with mine 3 years ago, not the same but similar, would backfire under load. I chased it for probably 3 months, finally gave up and put new wires and cap/rotor on - solved the problem. I also put in a new O2 Sensor and coolant temp sensor before figuring it out, replaced all the vacuum lines, new spark plugs.
03-18-2016, 04:46 PM | #5 | |
I'm currently swapping a TBI into a carb'd truck, and am pretty comfortable with TBI at this point, but if you're not throwing codes, that makes it tougher, but it means you can kinda (but not 100%) rule out sensors. If they were out of range with what the other half dozen sensors are doing, it'd likely pop a code. An EGR valve could be an issue (See here) so it's something to check. Basic plugs, wires, cap, rotor. Check the little things first.
Current Projects: 1984 GMC, LWB Fleetside, 305/350 - Currently Doing TBI Conversion 1966 GMC, SWB Stepside, 350/200-4R - Currently waiting patiently. |
03-18-2016, 08:17 PM | #6 |
STILL PLAYS WITH TRUX
I'd ck the vacuum lines goin to the EGR and all of 'em for that matter then I'd remove the EGR line from the manifold side and either use a vac pump if u have 1 or just suck it! The EGR should move to the open position and return to closed by spring pressure when u quit suckin' If it works leave it alone maybe ck the EGR mount gasket for leaks.
There is one other thing that can cause a similar problem like yours and that is the fuel pressure regulator it may have a ruptured diaphragm or a broke or week return spring. Good luck. |
03-18-2016, 09:58 PM | #7 |
In addition to the above recommendations, I would check the Throttle Position Sensor too.
Keep your head up...and your stick on the ice. |
03-19-2016, 10:10 AM | #8 |
With no codes I would look at fuel pressure, vacuum and timing. Those things aren't monitored by the ECM. Could be ECM too.
76 Chevy K20 76 GMC K15 77 Chevy C10 77 Chevy K10 |
03-22-2016, 08:46 AM | #9 |
Thank you so much guys! You've given me a major head start!
No codes at this time, cap/rotor plugs/wires were done in September. My dad wants me to check the coil. I pulled the EGR off and cleaned it and the port and blew it out with air and put it on with a new gasket and now it's no no where near as bad but still noticeable. Still driving the truck daily. |
03-22-2016, 11:23 AM | #10 |
try unplugging your EGR valve altogether and running it that way. You will get the CEL to come on after a while, but if it runs way better other than that, you'll know what the problem is. That is how I was able to diagnose mine.
other than that - it sounds like you could have a timing advance or fuel pressure issue.
1967 CHEVELLE MALIBU 427/700R4 1971 CHEYENNE 10 350/350 1983 GMC K3500 454/400/205 1987 R10 TBI 350/700R4 2014 CRUZE 2.0 TURBO DIESEL |
03-25-2016, 09:43 AM | #11 |
So I ran it with no EGR, seemed to run a little better, but I finally popped a SES light. Low voltage at TPS, DTC 22...
03-25-2016, 11:47 AM | #12 |
Have you checked the Coolant temperature sensor that is ontop of the intake?
i had a 94 TBI that had the same kinda problem. Couldnt figure it out, i replaced everything, EGR sensor, o2 sensor, etc. and the problem ended up being the coolant temperature sensor. When that sensor goes it doesnt throw any codes and it acts like it is trying to start in extreme cold weather (Something like -80) and just dump fuel into it making it run rich and stumble and so on. |
