Old 03-18-2016, 05:36 PM   #1
jdl71
jdl71's Avatar
door hinge backing plate r&r
I assume the only way to get access to these is to cut a hole either in the pillar or inside the cab? I have an upper that has broken loose from what ever keeps it from falling backwards and wanted to be sure I wasn't missing something before I started slicing my cab up.
Psalm 23
64 C10
66 K20
jdl71 is offline   Reply With Quote
Old 03-18-2016, 08:20 PM   #2
racecougar
racecougar's Avatar
Re: door hinge backing plate r&r
That's correct. You'll have to cut in order to gain access.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 03-19-2016, 12:34 AM   #3
Tazimafied
If you can still get to the plate and bring it back up where it should be you could remove the paint and find the spot welds that held it on. Drill them out then use short bolts to hold the backing plate in place and plug weld where you drilled. Its a lot more finicky but would save trying to refit the cut out section.
Tazimafied is offline   Reply With Quote
Old 03-19-2016, 09:07 AM   #4
jdl71
jdl71's Avatar
Well now that I have it cut out, now what? Naturally I did not cut out enough of the pillar to have room to fix and reattach the rusted out bracket. Anyone have a suggestion on how to re engineer this?
Psalm 23
64 C10
66 K20
Old 03-19-2016, 09:51 PM   #5
racecougar
racecougar's Avatar
You need to cut out a large enough section of the pillar to bench repair then reinstall. Your cuts should be at least a couple of inches above and below the hinge bolt holes in order to leave enough material for the little brackets that retain the backing plate.
Old 03-20-2016, 11:26 AM   #6
jdl71
jdl71's Avatar
That's what I was afraid of.
Psalm 23
64 C10
66 K20
