03-18-2016, 05:50 PM | #1 |
Fuel Line pump to carb
I tried to do a search but the results were overwhelming. I have a 66 292 C20, my son is starting to tinker with in autoshop. He cracked the steel fuel line taking the carb off. I am finding 1967 lines, but not 60-66. Would that 67 work? Is there much difference in the 292 between those years? What are some other options-rubber, I found some guys saying they used steel brake line bent carefully, steel braided?
03-18-2016, 06:31 PM | #2 |
Re: Fuel Line pump to carb
Pretty straight forward to bend and flare a new one, using the original as a sample. Fittings and steel line are available at most of the automotive stores.
They may even have a tool loan program for the flaring tool and bender. I try to avoid using rubber fuel line as much as possible. |
03-18-2016, 09:42 PM | #3 | |
03-18-2016, 11:07 PM | #4 |
Agree with what's been said. Be good practice for sure, and he can custom make the line even.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
