Old 03-19-2016, 01:35 AM   #1
Isaiah92260
Isaiah92260's Avatar
Am I bench bleeding right?
I just put these plugs in after I was done so it won't keep leaking. I bench bleed it with these plugs off and got a good flow sometimes, I feel like I have air occasionally, I made sure there was always fluid.. Probably bench bleed it for a hour or more straight while I was watching tv lol.... But I noticed this 67 brake cylinder didn't come with the rubber hose to bleed with, just these two blue plugs.... Does it sound like I didn't every thing right? This it my first time bench bleeding
Isaiah92260 is offline   Reply With Quote
Old 03-19-2016, 08:08 AM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Am I bench bleeding right?
Here is a handy video clip on this.
https://www.youtube.com/watch?v=vOTkVAeU_n4
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 03-19-2016, 01:24 PM   #3
chevy2tom
chevy2tom's Avatar
I picked up a universal kit from napa $8
chevy2tom is offline   Reply With Quote
Old 03-22-2016, 03:03 PM   #4
GRX
GRX's Avatar
Should not take more than a couple minutes to force all the air out. When pumping, be sure the reservoirs do not go dry. Then you have to start over. Get the kit recommended above.
Even with those plugs you will likely get air in there when installing the lines. Pump to the wheel cylinders until all air is removed.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
