250 manifold vacuum ports differences
I am replacing my intake manifold on a 250 6 cylinder and the replacement manifold I purchased does not have a vacuum port on the top of the manifold like my original one has. I was using the one on top for the PCV valve and the one on the side for my power brake booster. Can I use the side port for both PCV and brake booster or do I need to look for another manifold?
Re: 250 manifold vacuum ports differences
Just drill and tap the new one for the fitting.
You shouldn't combine the pcv and booster on one. |
Where is the best place to tap? The metal seem thin in the same place the OG manifold is ported.
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
There was an adapter fitting that went on the side of the manifold that was included in the dealer installation kit.
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
If your not particular of originality you could use one of these with adapters.
Ordered this from Summit.
Installed new vacuum port fitting and everything is working as it should!
Great, would you have the Summit part # handy for someone else to reference?
Classic Performance IN38V60-C - Classic Performance Vacuum Fittings and Assortment Kits
Summit Part Number: CLP-IN38V60-C |
#13 |
Post Whore
![]() Join Date: Mar 2013
Good stuff to know.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
#14 |
Installed
Posted via Mobile Device |
