Old 03-19-2016, 07:16 PM   #1
Gregski
Post Whore
Gregski's Avatar
Cylinder Head Gaskets Water Jacket Inquiry
Gentlemen I hope I can explain my question properly as it pertains to the 350 Small Block Chevy (SBC).
How come the water jacket holes in the cylinder heads are so big, yet the gaskets we buy for them have this restricted hole in them the size of a hole punch in your binder paper.
Seems like deliberate / built in restrictions.
Why make the openings in the cast iron so big, if you are going to restrict them with a gasket?
Gregski is offline   Reply With Quote
Old 03-19-2016, 07:21 PM   #2
Gregski
Post Whore
Gregski's Avatar
Re: Cylinder Head Gaskets Water Jacket Inquiry
Same goes for the engine block, the block has three holes the size I could put my thumb through, yet the holes in the gasket are only big enough for my pinky.
Old 03-19-2016, 07:53 PM   #3
burban nate
I would guess that the holes only need to be as big as the gasket for proper operation. However, the holes in block and heads needed to be big enough for the sand cores to be extracted after they were cast.
Nate
Current Project: 1990 V3500 CC dually.
burban nate is offline   Reply With Quote
Old 03-19-2016, 07:58 PM   #4
Blessed66
Blessed66's Avatar
I was gonna say restriction.
Part of what helps water and antifreeze keep these engines cool is the water being there long enough for it to pull heat from the cylinders (or other hot things). If it flowed freely, it wouldn't leech heat away from the engine like it's suppossed to.
Current Projects:
1984 GMC, LWB Fleetside, 305/350 - Currently Doing TBI Conversion
1966 GMC, SWB Stepside, 350/200-4R - Currently waiting patiently.
Blessed66 is offline   Reply With Quote
