Old 03-19-2016, 11:32 PM   #1
62chevy302
hillbilly
62chevy302's Avatar
65 c10 sway bar help needed
I just bought a sway bar off of a 79 c30. I bought the cpp brackets for lowered trucks. Im trying to locate the cpp brackets using txfirefighters method,but i think his thread is for a 67-72 truck. Im not sure what to go by?
-1962 C-10
62chevy302 is offline   Reply With Quote
Old 03-20-2016, 12:25 AM   #2
62chevy302
hillbilly
62chevy302's Avatar
Re: 65 c10 sway bar help needed
Here i am holding the cpp bracket up to the frame. This is where it needs to be if i put the sway bar ends flush with the backside of the bushings on the control arms.
-1962 C-10
Old 03-20-2016, 12:33 AM   #3
Blue666(2)
Great Upgrade!
I started kind of back to front. I attached the ends to the A arms first and the then swung it up to the frame. After attaching the frame bushings, it was easy to mark the locations to drill the holes. I would play with it alot before drilling any holes.
Good Luck!
Blue666(2) is offline   Reply With Quote
Old 03-20-2016, 03:22 AM   #4
62chevy302
hillbilly
62chevy302's Avatar
I found this in the faq but its for a ece setup.
http://www.hotrod.com/how-to/chassis...y-bar-install/
And this is the pic showing the first hole location
It looks like 3" on the dot
-1962 C-10
Old 03-24-2016, 07:35 PM   #5
62chevy302
hillbilly
62chevy302's Avatar
Originally Posted by Blue666(2) View Post
Great Upgrade!
Good Luck!
How far did you let the swaybar stick out of the bushings on the a arms?
-1962 C-10
Old 03-24-2016, 07:48 PM   #6
Joemomma1
Joemomma1's Avatar
Great Upgrade!
Good Luck!
Same here. I left about .5"-1" of the bar past the bushing. Can't remember exactly.
Joemomma1 is offline   Reply With Quote
Old 03-24-2016, 07:56 PM   #7
Blue666(2)
It's been a few years but I remember about 1/2" to 1".
I do recall that the first time I tried I put jack stands under the frame and the wheels hung free. I could not get the sway bar any where close.
The second attempt, I drove up on a set of rams and it nearly bolted itself on.
