Old 03-20-2016, 12:34 PM   #1
ebaby35
62' x-frame to ladder frame
I have an extra frame that I wanna play around with and get rid of the x-frame and make into a ladder frame. Would doing this allow me to buyu stuff that fits on the later 63' frame? What things would be need to make this happen?
ebaby35 is offline   Reply With Quote
Old 03-20-2016, 01:20 PM   #2
ebaby35
Re: 62' x-frame to ladder frame
Picture of frame that I want to change
Old 03-20-2016, 09:02 PM   #3
LVPhotos
LVPhotos's Avatar
You can find just as much stuff for the x frame as the ladder. In fact Porterbuilt has a x member to stiffen the ladder bar frame, as seen on Gas Monkey Pikes Peak truck. So your not winning by swapping enless your making a shorter frame. PORTERBUILT has everything I used and 72-87 spindles work with ball joints, keep torsion bars to have nicer ride. Parts are what you make of it.
http://67-72chevytrucks.com/vboard/showthread.php?t=623704
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 03-20-2016, 09:21 PM   #4
ebaby35
Ok thanks for the help I was thinking that making my extra frame into a 63 would allow me to easier add aftermarket parts that arent available for the 62.
Old 03-21-2016, 12:00 AM   #5
Captainfab
60-66 Nut
You aren't going to end up with a '63-'66 frame just by removing the X from the middle. The '60-'62 frames are also wider from the front suspension back. If you don't like the '60-'62 frames, just find a '63-'66 frame. A '67-'72 frame will also work, but with some extra mods. If you do change frames, be sure to do it legally. Check with your local DMV.
Old 03-21-2016, 06:15 AM   #6
notsolo
notsolo's Avatar
IMO X frames are stronger, front cross member swap from a 72-87 is just as easy, 22 gallon Poly gas tank from a 1992-1996 caprice wagon works well with the extra width in the back.
notsolo is offline   Reply With Quote
Old 03-21-2016, 10:47 AM   #7
patrickk1
I agree. I'd rather have the x-frame and make the very minor mods necessary to do a 72-87 swap or aftermarket setup.
- Patrick
1964 GMC pickup lwb ~ My newest build!
1937 Ford Coupe ~ Custom frame, LS1, quickchange
1950 Chevrolet 3100 ~ Bagged (Sold)
1931 Chrysler Roadster ~'32 Ford Frame, Channeled 8" (Originally a 60's show car)
1967 Chevelle ~ 454 Triple Black (Sold)
1964 Chevrolet Impala SS (Sold)
patrickk1 is offline   Reply With Quote
