03-20-2016, 01:19 PM | #1 |
Jaguar V12. Which transmission?
I'm putting a Jaguar V12 into a 66 Suburban and have the transmission down to two choices. I'd like to have overdrive for the mileage and the V12 comes with a GM T400 but uses a Jaguar specific bellhousing bolt pattern. So I could keep the T400 and add a Gearvenders Overdrive or use an adapter plate to mount a 4L60e with a FAST EZ-TCU. Any body have any thoughts?
Dale ---------------- My suburban's Twisted Little Sister http://67-72chevytrucks.com/vboard/s...d.php?t=655167 |
03-20-2016, 02:39 PM | #2 |
Moderator
Re: Jaguar V12. Which transmission?
Third option (and the one I would take), adapter plate with TH700R4/4L60 (non E, no controller needed).
03-20-2016, 05:08 PM | #3 |
Hi Dale,
I have started a question thread on Rods n Sods to ask the same question. Let's hope you get some good answers. http://www.rodsnsods.co.uk/forum/cha...ication-430290 Click link above.
MY BUILD LINK: http://67-72chevytrucks.com/vboard/s...585901]Redneck Express - 1966 C10 Short Fleetside MY USA ROADTRIPS http://forum.retro-rides.org/thread/...2018-humdinger IF YOU CAN'T FIX IT WITH A HAMMER, YOU'VE GOT AN ELECTRICAL PROBLEM MATE. |
03-20-2016, 11:53 PM | #4 |
60-66 Nut
I would use an adapter plate with a 4L80E and an aftermarket controller.
03-21-2016, 10:37 AM | #5 |
Not sure which vintage v12 or your familiarity with them, but if you haven't already or don't know, replace the timing guides and tensioners now if they're oem. Aftermarket ones i don't think have the issues that the OEM ones did in the XJS series v12s.
Project "i'm just going to clean up the interior and the engine bay": http://67-72chevytrucks.com/vboard/s...d.php?t=550931 |
03-21-2016, 03:43 PM | #6 |
Well, looks like my bright idea to try get some info has delivered nothing.
Sorry.
03-21-2016, 08:03 PM | #7 |
Thanks for the ideas guys. I haven't decided which way to go but I'll figure it out.
Rian, Thanks for putting in the extra effort and posting the question in the UK.
