Old 09-24-2003, 10:47 PM   #1
Lynx
Lynx's Avatar
Lightbulb How many and what kind do i need?
I’m planning on replacing my all my dash bulbs this weekend but want to be prepared! How may bulbs should I pick up for my 83 with gauges? Also anyone know what size/part number i need.
Also any advice on removing the cluster is appreciated. At the same time I plan on lubing my speedo cable what should I plan for that?
Thanks Ben
Ben
1983 Silverado SWB 305
2002 Silverado Extended Cab 5.3
http://members.shaw.ca/bkennett
Lynx is offline   Reply With Quote
Old 09-24-2003, 11:53 PM   #2
Russell
Professional Grade
Russell's Avatar
It is a fairly simple task to remove the different guages to replace the lightbulbs and such... Be VERY careful when you remove the blue pod in the back, that left bracket breaks wayy to easily... If you do remove the pod, I would highy suggest you clean it up and spray paint the whole thing a nice shiney silver color, it will dramatically improve the brightness of your panel at night. I dunno what number the blubs are, but I can snap a photo of one for you tommorow when I get back in...
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 09-25-2003, 12:33 AM   #3
junkyardpartseeker
bulbs
The bulbs are 194's. They plug into the black sockets that press against the PC on the back of the cluster. Get about 10 or so and that should cover you on it.
Tommy Davis
junkyardpartseeker is offline   Reply With Quote
Old 09-25-2003, 04:37 PM   #4
78SilveradoSWB
78SilveradoSWB's Avatar
There are 12 bulb positions in all. 2 positions are for the turn signal lights and 2 positions to illuminate the two idiot lights for below the speedometer for 4X4 engaged and Brake/Alt warning lights. The other 8 are for the back lighting.
Mitch
1978 Chevrolet Silverado C 10
454 BB, TH400
78SilveradoSWB is offline   Reply With Quote
Old 10-05-2003, 06:21 PM   #5
Lynx
Lynx's Avatar
So whats the trick!! i got the bezzel off and the dash loose the cluster is loose in there but i cant for the life of me get it out! i dont want to smash on it to bad cause one of the tabs already broke off but thats no big deal if i can get this damn thing outta here!
Ben
Ben
Old 10-06-2003, 09:54 AM   #6
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
Did you remove the speedometer cable from the back? There is also a little wire connector with a really small screw thats attached. Not sure if that is just if you have cruise control or not.
There is a clip that you have to push up on and pull the cable at the same time. It also has to be pushed up when it goes back on. Its not real hard but it can be at times
MylilBowTie is offline   Reply With Quote
Old 10-06-2003, 10:06 AM   #7
Russell
Professional Grade
Russell's Avatar
Also, your oil pressure guage may have a cable on it...
Old 10-06-2003, 11:55 AM   #8
Lynx
Lynx's Avatar
Yeah i got caught up on the speedo cable and couldnt get it off, i need to look at one that isnt in the truck to see how its suoposed to come off. i replaced a few lights and it seems that im missing a few a sockets as well so i guess i can live with it untill i can aford real gauges
Thanks for the help
Ben
Ben
