Old 03-21-2016, 01:17 PM   #1
JMD
JMD's Avatar
Which booster/MC combo for disk/disk
I sat down to order a master cylinder/brake booster and realized there are a ton of options out there, turns out I'm not quite up to speed when it comes to brake systems, and a search here just got me more confused...
I'm working on a '67 K20 with disks all the way around ('75 K20 calipers and rotors on all four corners). I'm thinking I can use the stock booster, but which master cylinder should I get? What about a proportioning valve? Can someone please explain exactly what I should be looking for? Maybe dumb it down and use small words so I don't become even more confused...Thanks
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296
JMD is offline   Reply With Quote
Old 03-21-2016, 02:23 PM   #2
davepl
davepl's Avatar
Re: Which booster/MC combo for disk/disk
Not an expert, but I'd get the stock setup form a '75 K20 and run that. Is there any reason not to? The factory paid some clever engineers to build it as a system and you've already got most of it.
Failing that a disc/disc master and prop valve from a late 60s Corvette has usually sufficed. Or you can use an aftermarket unit.
I'd strongly recommend using all the factory pieces from pushrod to pad.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-21-2016, 02:53 PM   #3
JMD
JMD's Avatar
Will a '75 MC bolt up to my '67? I agree that going with all matching parts would be ideal, but I'm not sure if they are compatible...
What if I just used a '67 K20 booster and MC, and then used an aftermarket proportioning valve?
Old 03-21-2016, 03:12 PM   #4
67 chevelle
67 chevelle's Avatar
you need a valve like this
http://www.ebay.com/itm/Brass-Combin...EaIA9Q&vxp=mtr
suposedly , I have used a disc drum combo vale with disc's on all 4s before with no issues ,,, butt,,, there are always variables that may make that less than ideal for you
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 03-21-2016, 04:36 PM   #5
kehstr
kehstr's Avatar
if you really want brakes that will stop on a dime, put hydroboost in it
kehstr is offline   Reply With Quote
Old 03-22-2016, 01:20 PM   #6
JMD
JMD's Avatar
Thanks, that's exactly what I ordered. Hopefully it works!
Old 03-22-2016, 01:26 PM   #7
csfields
csfields's Avatar
I went with a Wilwood 1 1/8" bore master cylinder, stock brake booster, right stuff disc / disc proportioning valve. All works great together on my 14" rotors.
Thanks,
Casey
71 Chevy C-10 SWB 350/400 PS, PB
The Build http://67-72chevytrucks.com/vboard/s...d.php?t=584045
The Brake Upgrade http://67-72chevytrucks.com/vboard/s...d.php?t=695699
csfields is offline   Reply With Quote
Old 03-23-2016, 01:10 PM   #8
davepl
davepl's Avatar
Honestly I tried that on a marginal system once, they're not magic. If you've got a giant cam and no vacuum they're the perfect solution, but there's not that much more assist than with a good vacuum booster, or that was my experience...
Old 03-23-2016, 01:15 PM   #9
kehstr
kehstr's Avatar
The thing i love most about hydroboost, is they always have pressure, vacuum brakes can be hit and miss depending on the rpms of the motor. If you can find the right vacuum booster they work good, but i have gotten sick of trying boosters, so sense i know hydroboost works i go with it.
Old 03-23-2016, 03:21 PM   #10
Billhilly
Billhilly's Avatar
As far as master cylinders go for disc/disc I have just finished an all new install in a 72 K2500 with stock front and Eldorado rear calipers. CPP sold me a 1" cylinder specifically for the job that I blindly installed and plumbed up. It gave me brakes, but a very long pedal (almost to the floor). After much discussion I swapped in a 1 1/8" cylinder and problem cured! So personally, there is no discussion. 1 1/8" gives you the volume you need for calipers. Calipers require more volume than wheel cylinders.... Oh, stock booster, Wilwood adjustable proportioning valve. Oh again, Thanks for nothing CPP!
1972 K2500 Long Box
400/350
Billhilly is offline   Reply With Quote
