Old 03-21-2016, 03:46 PM   #1
sipper
sipper's Avatar
upper rad hose Ls swap
I'm putting an ls with a corvette waterpump in a 67 C10 along with a Champion Radiator that has the upper rad hose on the Drivers side. The water pump being from a corvette has the hose coming out the front. A corvette upper rad hose almost fits, except it is too small to fit the rad.
Has anyone found an upper rad hose that will fit this combination?
sipper is offline   Reply With Quote
Old 03-23-2016, 08:43 AM   #2
sipper
sipper's Avatar
Re: upper rad hose Ls swap
No one has figured out a hose for this, or is everyone using the truck waterpumps?
Old 03-23-2016, 08:58 AM   #3
The Chainsaw
The Chainsaw's Avatar
I usually end up finding a straight spot in the hose, cut, add a piece of pipe, and find another radiator hose that I can cut to make the side for the radiator work.
It's a pain, but I also drill and tap a hole in that piece of pipe for the steam vent tube.
The Chainsaw is offline   Reply With Quote
Old 03-23-2016, 09:23 AM   #4
Aruba1
I used the old LS hose and made it fit. This is when the upper outlet was on the driver side and also when I later switched to the outlet on the passenger side by recutting the same hose.
Aruba1 is offline   Reply With Quote
Old 03-23-2016, 09:59 AM   #5
Oldblue68chevy
I will get you the number for the hose I used later today. I bought it at the local autozone. I just had to cut the end and then flare it a bit to fit over the radiator inlet. I am using and f body pump and a champion rad. I will also post a pic of it.
Oldblue68chevy is offline   Reply With Quote
Old 03-23-2016, 10:14 AM   #6
sipper
sipper's Avatar
Thanks for the reply's
OldBlue sounds like you have the same setup as me. The part number and a pic would be much appreciated.
Old 03-23-2016, 10:23 AM   #7
DBK81
DBK81's Avatar
Soak it in hot hot water for 5 min, this will make all the difference. It will fit.
1972 C10 - It might be old, but it's not slow
DBK81 is offline   Reply With Quote
Old 03-23-2016, 10:27 AM   #8
Oldblue68chevy
I was going to suggest the same thing DBK81 said. Even the one I bought needed cut and expanded. Hot water will get it flexible and it will slip right on.
Old 03-23-2016, 12:45 PM   #9
davepl
davepl's Avatar
I'm going to swap over to a Ron Davis radiator due to this (I don't want a really long radiator hose that would result from transporting the coolant all the way to the other side) and the steam vent stuff. But I'd be curious to see a pic of anyone who's done it (well, of the rad, not the person).
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 03-23-2016, 04:52 PM   #10
Oldblue68chevy
Here are pics of my upper hose. 71425 at autozone. Also note that my engine is moved back as far as the slider mounts would allow.
Old 03-23-2016, 05:40 PM   #11
davepl
davepl's Avatar
Not sure if it'd clear my planned accessory drive, but that's not too bad!
Old 03-23-2016, 05:47 PM   #12
Oldblue68chevy
Yeah I am running the f-body pump with truck accessories.
Old 03-23-2016, 06:02 PM   #13
sipper
sipper's Avatar
Thanks for the replies it helps a lot
