![]() Join Date: Jul 2009
1968 K10 Frame Question
I was looking at a 68 K10 for sale and was trying to find the frame serial # and I saw this raised area on the frame where I usually find the frame serial #. Is this frame modified or is this supposed to be there?
Go Pack Go!
Re: 1968 K10 Frame Question
Could it be a frame crack repair?
a close up picture would help
All about them K’s
![]() Join Date: Jun 2014
Looks like a peice of steel welded to the frame to me. Definitely not original. It should be the same shape, height and contour of the surrounding area of the frame. As said above it could be a crack repair
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 315/75/16's ‘87 IROC-Z all original 50K mile survivor TPI 305 IROC Blue ‘10 Camaro 2SS/RS Aqua Blue Metallic #93 -version 2.0 ![]() |
That's been welded. You can see the bead of a weld if you zoom in on the inner rear section of the mysterious lump.. Sketchy if I do say so myself. Just bought a new frame for my 67 cause my old one was "repaired" by po
1967 Chevy CST 10 1969 Chevy C/20 Longhorn 1969 K10 Suburban 1972 Chevy Cheyenne Super 10 turned K30 (sold) ![]() |
Thanks for the help guys. Too bad, body was in decent shape. . .Here is closer pic.
Junior Member
those steel brake lines look like their just going through a small hole made by a torch or something. awful close fit??
1969 impala conv 427 #s loaded. dad bought new 1969 "Judge" RA-3, rare warwick blue/white, #'s 1968 vet convertible #s 427/435 tripower (sold) 1968 belair 2door post #s 427/385 1936 ford 5w coupe dads 1st car 1969 camaro ss (17,xxx) miles Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project. |
