Old 03-21-2016, 10:05 PM   #1
AustinBelair
Does this sound about right?
About to order the rear-end build parts for the truck. I'm using the stock rear housing that I just had powdercoated.
Detroit Trutrac
Moser 30 Spline 5 lug axles
Yukon gear 3.73
Moser bearing support diff cover
Axles seals, gear install kit etc
My mother is a recent cancer survivor and this truck build is for her
AustinBelair is offline   Reply With Quote
Old 03-22-2016, 12:53 AM   #2
Captainfab
60-66 Nut
Re: Does this sound about right?
I am assuming your last item includes all bearings, races and seals? Do you still have the original internals, so you have a source for small parts such as the C-clips?
Old 03-22-2016, 06:27 AM   #3
PGSigns
PGSigns's Avatar
The only thing that may give you trouble is the rear cover. Depending on your setup they can get in the way of the panhard bar. For most driving the cover is over kill. If you plan to drive the truck alot you may want to look at a 3.42 gear.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
