09-25-2003, 12:05 AM | #1 |
Getting cabin fever?!?!?!
removal of stripped bolts in locking hubs
hey guys. i realize this is a question regarding my ford, but locking hubs are locking hubs. here's my problem. i'm trying to change the u joints in my front axle. 4 bolts are stripped out from the PO. i've tried the correct size allen key, pounding a screwdriver bit in, easy outs (snapped off). i've been using penetrating oil (swear i heard it laugh at me). i'm not worried about hub body damage as i'll be installing warn units next summer. i need to change the joints before winter tho. and before it gets any colder. thanks
Member of the Discs Up Front Club 1972 GMC 1500 1994 F-150 XL 4x4 Tact is for people not whitty enough to be sarcastic |
09-25-2003, 09:31 AM | #2 |
hubs
use a cobalt drill bit and drill the head off, then when the hub is off use a pair of vice grips to get the bolt out. use antiseze when you put it back together.
troy wilson |
09-25-2003, 10:05 AM | #3 |
that's what i figured. thanks man. off to the hardware store again!!
09-25-2003, 10:33 PM | #4 |
GAS AXE, GAS AXE , Torch em' off LOL Nah just do what Troy said , Very simple fix just take your time and be easy with the visegrips. Cause if you break them off in spindle the doo doo gets deeper and stinks worse too.
EXPERIMENTAL STAGES OF SANITY _____________________________ Run whatcha brung, and hope you brung enuff |
09-26-2003, 06:26 AM | #5 |
BOLT
actualy there is something to what trukkers69 said. if the bolts are still being difficult after the hub is out of the way, heat the bolt, then let it cool, then try the vice grips again.
troy wilson |
09-26-2003, 11:16 AM | #6 |
Use a reverse twist bit when you drill: it may end up coming out when you do the initial drilling.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
