Old 03-22-2016, 01:39 PM   #1
63frankintruck
Converting 63 to a 700R4, different driveshaft?
When converting a 60 3C 10 to a 700r4 ,do you keep the two piece driveshaft or change it to one piece?
thanks for the help!
63frankintruck is offline   Reply With Quote
Old 03-23-2016, 12:02 AM   #2
Captainfab
60-66 Nut
Re: Converting 63 to a 700R4, different driveshaft?
If your truck is a long bed, I would keep the 2 piece. Just have the front shaft shortened.
Old 03-29-2016, 10:09 AM   #3
63frankintruck
Thanks for the info
Old 04-08-2016, 10:30 PM   #4
63frankintruck
Old post I know, it's time to order my rebuild kit for 12 bolt, need to replace diff yoke.
My question- should I upgrade to the larger U joint?
Will one piece d shaft from donor truck work in 63?
