Old 03-22-2016, 06:59 PM   #1
YOLO
Custom Truck Lover!
YOLO's Avatar
What size 17 inch tire to use
I am using 17inch FJ steel wheels on my 64. I have a 4/5 static drop. What size tires are you guys running on your 17's? I have read 245/45/17 but I would like more input.
Squarebody guy
YOLO is offline   Reply With Quote
Old 03-22-2016, 09:18 PM   #2
blown240
blown240's Avatar
Re: What size 17 inch tire to use
I was doing research on this myself a few months back. I currently run 235-75-15 tires, and was going to go to a 235-65-17 since they are almost the same height.
Not sure if that helps or not. But either way, please post pics once you have those wheels on. I am seriously considering the same wheels!
'61 Panel - Helms Bakery Truck - Daily Driver - FOR SALE
blown240 is offline   Reply With Quote
Old 03-22-2016, 11:13 PM   #3
YOLO
Custom Truck Lover!
YOLO's Avatar
I need more help.
The tires I have now are 205/70/15 and I want to get a tire for my 17s that will fill the wheel well. I am not going to bigger wheels. When I do a tire size comparison with a 245/45/17 it is smaller.
Squarebody guy
Old 03-23-2016, 02:52 AM   #4
Slow Build
Slow Build's Avatar
Those wheels look pretty narrow. They look to be around 6" wide. The widest tires that will look right on those would be a 225, possibly a 235. Personally I think these trucks look good with a 28" tire so that would be a 60 series in those sizes (225/60/17 = 27.6" diameter, 235/60/17 = 28.1").
Current Ride: 1964 C-10 Short Fleetside
Daily Driver: 2005 GMC crew cab short fleetside /2001 Chevy Tahoe
Past GM Trucks:
1959 GMC short stepside
1968 GMC short stepside-4x4
1973 Chevy short stepside
1989 Chevy short fleetside-reg cab
1993 Chevy short fleetside-Xcab
2002 Chevy short fleetside-Xcab
Save the dinosaurs, use synthetic oil.
Slow Build is offline   Reply With Quote
Old 03-23-2016, 06:36 AM   #5
PGSigns
PGSigns's Avatar
I am with Rick on this one to fill the wheel well nicely a 28" tire work well. That is what I am running but on 15" wheels. I think those wheels are 7.5" wide with 4 1/2" of back spacing. You may be able to get away with the 245 on the rear but the front may have issues in the front with your drop. It may fit OK or be close it is hard to tell. You could get your rear set mounted and bolt them on the front and see how it fits and if your good get the second set.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-23-2016, 08:52 AM   #6
YOLO
Custom Truck Lover!
YOLO's Avatar
The wheels are listed at 7.5 inches but I measured at 8.5 from lip to lip. I like the idea of a taller tire 28 or 29 inches. I am thinking 255/60/17 (29) or 255/55/17 (28). Ill post pictures after I do it. I will buy tires in the next week.
Squarebody guy
Old 03-23-2016, 10:30 AM   #7
chevy_mike
Never Ending Projects
chevy_mike's Avatar
On my 17x8 wheels, I used a 235/60-17 tire, which comes out about 28".
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-23-2016, 10:56 AM   #8
YOLO
Custom Truck Lover!
YOLO's Avatar
That looks perfect. Great color too!
Squarebody guy
Old 03-23-2016, 11:16 AM   #9
PGSigns
PGSigns's Avatar
Did you measure inside or outside? Inside at the bead is where you need to measure.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 03-24-2016, 12:47 PM   #10
jimmyjammoto
FWIW, I went on the recommendation of 245/45r-17 for tires and I'm severely disappointed. They look too small for the size of the truck. Like those 235/60's. About perfect.
jimmyjammoto is offline   Reply With Quote
Old 03-24-2016, 12:56 PM   #11
jimmyjammoto
Also, I should add I'm using the FJ rims with a 4/6" drop.
Old 03-24-2016, 01:33 PM   #12
YOLO
Custom Truck Lover!
YOLO's Avatar
I went with 235/60/17 Falken tires at $88 each. I will mount them on my truck later today and post a picture.
Name:  2016-03-24 10.09.28.jpg
Squarebody guy
Old 03-24-2016, 06:13 PM   #13
chevy_mike
chevy_mike's Avatar
Cool, looks good.
Old 03-24-2016, 08:14 PM   #14
YOLO
Custom Truck Lover!
YOLO's Avatar
Bolted them on. The bed is just sitting there and not bolted on. I have to make a new cross member to go around the gas tank.
Name:  2016-03-24 16.14.00.jpg
Name:  2016-03-24 16.14.07.jpg
Name:  2016-03-24 16.14.23.jpg
Squarebody guy
Old 03-28-2016, 09:04 AM   #15
Desert.Chevy
Desert.Chevy's Avatar
You said you had a 4/5 drop, the pictures look stock height. I found these caps while looking for the wheels you have on ebayy and thought they might look cool with a Chevy logo panted in the middle. They kinda have that old artillery look to them.
Desert.Chevy is offline   Reply With Quote
Old 03-28-2016, 11:27 AM   #16
YOLO
Custom Truck Lover!
YOLO's Avatar
Those do look nice. I may just stay black or add a Chevy center cap later.
Squarebody guy
