Old 03-22-2016, 10:50 PM   #1
Jraney
Rear end
Hey fellas. I have a 64 that has a 6 lug rear end. I would like 5 lug. What's the best way to achieve this. Can I buy a 5 lug that will bolt right up with no mods. Thanks.
Jraney is offline   Reply With Quote
Old 03-23-2016, 12:13 AM   #2
Captainfab
60-66 Nut
Re: Rear end
If your 12 bolt is an all original '64 12 bolt, you will need to also change the spider gears to install the aftermarket 5 lug conversion axles. The other option would be to have your orginal axles plugged and redrilled to 5 x 5, but I would only do that if the wheel/axle bearing surfaces are in excellent condition.
Old 03-23-2016, 07:03 AM   #3
Jraney
Re: Rear end
Ok. Thanks. Where do you find the aftermarket 5 lug axles.
Old 03-23-2016, 10:49 AM   #4
vin63
It's Better With Nitro
vin63's Avatar
Re: Rear end
There are a couple of ways to go about getting aftermarket axles...one, is to work with a local differential shop where they would either cut you new axles, or order them from their supplier; two, is to work directly with an aftermarket axle company that makes new axles such as Mark Williams, Strange, Moser, Currie, etc.
For my street cars and hot rods, I usually work with a local differential shop.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 03-23-2016, 11:20 AM   #5
PGSigns
PGSigns's Avatar
Re: Rear end
Here is everything you need for the 17 spline setup.
Jimmy
http://www.speedwaymotors.com/1963-6...Kit,46254.html
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-23-2016, 03:11 PM   #6
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Rear end
I had mine re-drilled with 5 on 5 when I rebuilt the rear end. Cost was about $150 and had a racing machine shop do it...took a little time though but was worth it. Then buy the brake drums too. Also you will need to turn down the center of the axle at the plate to accommodate the drum.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
