03-23-2016, 11:32 AM | #1 |
Pedal Cover Installation
I bought new rubber pedal covers from LMC. They are really tight and difficult to install. Is there a trick to it? I've only tried them dry, but my next attempt will be wet and soapy. Is that the ticket, or is there something else I should try?
Thanks! |
03-23-2016, 11:45 AM | #2 |
Re: Pedal Cover Installation
GM or repop? My GM's installed OK dry. I did start with the wider section first and worked the edge around down both sides to the bottom.
03-23-2016, 01:03 PM | #3 |
Repop, I'd assume. They are the LMC ones, item #5 on page 50:
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=50 |
03-23-2016, 01:31 PM | #4 |
let it soak in the hottest water you can stand to put your hand in for 10-15 minutes
03-23-2016, 01:51 PM | #5 |
Dang, that's a great idea Willie!
Thanks! |
03-23-2016, 09:14 PM | #6 |
The Older Generation
Use a heat gun or your wife's hair dryer.... Don't tell her I told you to though... LockDoc
03-01-2020, 05:44 PM | #7 |
So you’re saying don’t try in cold weather ?
71 C-20 07 Magnum RT AWD |
03-02-2020, 06:11 PM | #8 |
Iv'e always used a little dish washing soap or baby shampoo on all rubber parts, pedal covers, gas tank grommets, rubber pads etc.
Just enough to do the job. wipe away excess when done. |
03-02-2020, 07:11 PM | #9 |
Appreciate the tip.
03-02-2020, 07:32 PM | #10 |
Use some 303 Aeropace Protectant, it will help the rubber pad slide on and it will also preserve the rubber.
1968 C20 Fleetside 396 4sp PS PB AC CST . https://www.youtube.com/watch?v=RWK8GgWD4uA |
