Old 03-23-2016, 06:56 PM   #1
Bruin_26
Question about vacuum port
So I'm just trying to figure out where the vacuum port between the carb and distributor leads to in my '72 C20 with a 350.
Bruin_26 is offline   Reply With Quote
Old 03-23-2016, 07:27 PM   #2
cleszkie
cleszkie's Avatar
Re: Question about vacuum port
It leads to the vacuum modulator on the rear passenger side of your TH350 tranny case. The modulator controls the shifting of the tranny.
cleszkie is offline   Reply With Quote
Old 03-23-2016, 07:31 PM   #3
70STOVEBOLT
70STOVEBOLT's Avatar
What do you mean "leads to"? Do you mean whether it is a ported vacuum source or not? If it's above the throttle plates it is ported if it's below the throttle plates it is considered manifold vacuum.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 03-23-2016, 07:38 PM   #4
FirstOwner69
FirstOwner69's Avatar
The one below? That's on my 69. Lines hooked to it are brakes, trans and A/C vacuum canister. Sometime after 1969 and before 1972 the brakes were hooked to the rear carb base if I recall correctly. It is a full engine vacuum port. Not sure what you mean by asking where it leads to.
Pic...
FirstOwner69 is offline   Reply With Quote
