Old 03-23-2016, 07:33 PM   #1
WOLFMANmike
WOLFMANmike's Avatar
any of you V8 HEI guys use these before ?
And we're they any good or even any improvement?
WOLFMANmike is offline   Reply With Quote
Old 03-23-2016, 07:37 PM   #2
racecougar
racecougar's Avatar
Re: any of you V8 HEI guys use these before ?
They won't erode as quickly as copper...thereby allowing a longer interval between replacement. You won't notice any difference in performance over a set of new copper plugs.
Rod @ AzzKicker Cars
1965 C10 SWB - Build Thread
racecougar is offline   Reply With Quote
Old 03-23-2016, 07:51 PM   #3
WOLFMANmike
so are you saying then that a copper plug is better for performance over these then ?
Old 03-23-2016, 08:32 PM   #4
PGSigns
PGSigns's Avatar
A good plug is a good plug. An engine with a decent tune up and a good set of plugs will not see a performance gain from plugs. A better plug just does a good job longer. Now if the plugs in an engine are carboned up and fouled you will see a gain from new plugs. I am old enough to remember pulling plugs out and cleaning them with a plug cleaner and putting them back in. I still have one of these.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-23-2016, 08:36 PM   #5
WOLFMANmike
Jimmy
Oh wow man that's friggin cool as hell right there .... I'm a lover of all things retro . So jealous right now lol is that from the 50s ? Or 60s don't even matter I want one of those lol
Old 03-23-2016, 10:36 PM   #6
racecougar
racecougar's Avatar
Not at all. Both will perform the same. The platinum plug will simply allow for a longer service interval.
Old 03-24-2016, 06:44 AM   #7
PGSigns
PGSigns's Avatar
The one I have I got in the 70's and not sure when it was made. Champion made a good looking one also. They do show up on ebay ever so often.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 03-24-2016, 07:03 AM   #8
WOLFMANmike
Jimmy
I have got to find me one of those if not just for the Nostalgia of it
Old 03-24-2016, 12:56 PM   #9
61K10
61K10's Avatar
Back in the 60's here in calif thrifty's kinda like a K-mart, had reconditioned plugs for around a $1. somebody just blasted them and put them in a package. as a kid with not a lot of money, these were the ticket lol!
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 03-24-2016, 04:19 PM   #10
WOLFMANmike
LOL I remember Thrifty. As a kid I loved getting their ice cream cones .... memories
Old 03-25-2016, 04:14 AM   #11
WOLFMANmike
was also thinking about buying some quality plug wires ... was looking at some Taylor Spiro core 8mm HEI Wires .... any of you ever use them ?
Old 03-25-2016, 06:15 AM   #12
PGSigns
PGSigns's Avatar
We ran Taylor on the racecars and they did fine. Have Taylor wires on my Harley.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 03-25-2016, 07:25 AM   #13
WOLFMANmike
Jimmy
Ok great thanks for the info
Old 03-25-2016, 11:51 AM   #14
luvbowties
luvbowties's Avatar
Smile Re: any of you V8 HEI guys use these before ?
Jimmy
Hey PGSigns, I went cheap & bought one of these in the '50's. Was a wall-mounted and did a good job thru 1986(used less and less as time passed: as engines used less and less oil) when I moved. Has a 2-position switch, 1 to blast with media and #2 to clean with air only after blasting. Still got it around here somewhere.
>> http://www.ebay.com/itm/VINTAGE-NOS-...467266&vxp=mtr <<.
I recall an AC blaster/tester at the Chevy d-ship that had a compressor/gauge/firing function to show how well it fired under compression. Shop manager let me, about 12 years old, use some of their equipment, including this. Worked, too, as some plugs failed to fire properly after cleaning & running the firing-under-comp test--as well as in the car.
Sam
luvbowties is offline   Reply With Quote
