Old 03-23-2016, 07:39 PM   #1
sharkskinman
need a really quick answer about piston Gap position
got the person out put the rings on I need to know which way the ring gaps are supposed to be pointing
65 I6 250
sharkskinman is offline   Reply With Quote
Old 03-23-2016, 08:35 PM   #2
PGSigns
PGSigns's Avatar
Re: need a really quick answer about piston Gap position
Just make sure they are facing the right side up and stagger the gaps. I put the oil ring wipers 180 apart and set them so the are not lined up with the pin. Compression rings I just set about 90 degrees apart.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 03-23-2016, 08:38 PM   #3
PGSigns
PGSigns's Avatar
Did you hone the cylinder? It is a must. Then wash it good with brake clean including the crank pin. After that spray it down with WD40 and wipe it out with a lint free rag a couple of times. Then oil it up good.
Jimmy
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
Old 03-24-2016, 11:57 AM   #4
65 C20
Probably a little late for you now but you also need to check the the ring in cylinder first to get the proper ring gap clearance.
The amount of gap you have when installed.
65 C20 is offline   Reply With Quote
Old 03-24-2016, 08:13 PM   #5
Marv D
Registered Truck Offender
Marv D's Avatar
Also a bit late to the party also, but there is new technology in ring gap orientation worth noteing.
If the rings are file fit, a good rule of thumb for MINIMUM ring gaps are:
Lower cost , pregaped ring sets are usually quite generous in ring gap and 3, 4 or 10 times the recommended gap. But always worth checking.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
