Old 03-23-2016, 10:25 PM   #1
Tiger Joe
Clearance for 1 piece driveshaft on LWB
Just did a tremec trans swap in my 67 long bed. I have to get a new driveshaft and was hoping maybe to go to a one piece. I searched and people have done it, but I don't see anyone saying how much clearance you need between the carrier bearing crossmember and the driveshaft. Or at least how much people have and if the shaft ever hit.
The local driveshaft shop recommended a 3.5" aluminum shaft for my truck. It's lowered and I just installed the CPP crossmember. My measurements say with a 3.5" shaft I would have right about 1/2" clearance. Doesn't seem like enough to me. Really don't want to back up my brand new crossmember.
Shop was worried about the length but did caution me I would need to make sure the driveshaft didn't hit the crossmember as one snack would likely ruin the $500 shaft
Tiger Joe is offline   Reply With Quote
Old 03-23-2016, 11:49 PM   #2
Clavo106
Re: Clearance for 1 piece driveshaft on LWB
I would think some one with drag racing experience can answer this question since they run safety loops on there drive lines.. the longer the shaft the more flex.. thats the reason for a two piece shaft with a carrier....
Clavo106 is offline   Reply With Quote
Old 03-24-2016, 07:10 AM   #3
Tiger Joe
I can't edit my post from last night but shop was NOT worried about the length, but cautioned about hitting it off something and ruining it
Old 03-24-2016, 08:06 AM   #4
Tiger Joe
doing some math on my notepad at my desk here this morning.
If I only have 1/2" clearance at the carrier bearing cross member (which is just over 1/3 of the way from the trans to the rear tires) that would basically mean my rear end can only move down 1.5" till the shaft hits. doesn't seem like enough to me
Old 03-24-2016, 08:25 AM   #5
Grumpy old man
Grumpy old man's Avatar
It's not enough clearance . $500.00 is a lot of $ for a drive shaft . 2 piece shafts were used just for this reason , Clearance! Unless you start making more room ( cutting the crossmember ) your not running a 1 piece shaft . Some parts just aren't made to work together without modification .
Grumpy old man is offline   Reply With Quote
Old 03-24-2016, 08:56 AM   #6
Tiger Joe
yup kinda what I figured not enough room.
I'll probably just have him shorten my stock 2 piece and hope it lasts.
Im running it behind my 600hp 496 BBC.
Edit: ya I wasn't too impressed with the $500 price, BUT he is the closest driveshop to me, less than 15 min away. otherwise I have to drive like an hour.
Old 03-24-2016, 09:25 AM   #7
Ironangel
Ironangel's Avatar
Location: Falls City, Nebraska "100 Miles From Nowhere"
The reason(s) GM used a two piece drive line are (1) Pinon angle. (2) A two piece drive shaft is stronger and will spin up more rpm before reaching maxium critical speed. They each have their pros and cons but the two piece pro's far outweigh the one piece cons of less weight and rotaing mass. A one piece shaft will deliver more instantainious response, but with more stress to the slip yoke and tail shaft bearing in the transmission as well as the pinon bearing(s) in the differential. For the cost of an aluminum shaft with an aftermarket crossmember, I could buy a case of carrier bearings and never worry about critical speeds or vibrations wiping out a bearing. Your shaft shop is correct to warn againt contact or strikes to the aluminum shaft because one slow hit on a speed bump or a racoon at 70 mph will do it in. Do some research, most all muscle cars and trucks, domestic and foreign, have two piece drive lines.~Ghostrider~
Michael of the clan Hill,
"Two Seventy Two's"
71 1-ton Dually 350 4-Speed
71 C/50 Grain Truck, 350 Split-Axle 4-Speed
02 3/4 ton Express
14 Indian Chief Vintage
1952 Ford 8N, "Only Ford Allowed On The Property"
"Be American, Buy American"
Ironangel is offline   Reply With Quote
Old 03-24-2016, 09:37 AM   #8
Grumpy old man
most all muscle cars have 2 piece driveshafts ??? Which ones ? I don't remember ANY muscle car using a 2 piece drive shaft with a carrier bearing midline ?
Old 03-24-2016, 10:03 AM   #9
67 chevelle
67 chevelle's Avatar
I think you just need your stock shaft shortened [don't let it go to your head] , that's what I did with mine , frame cut and stock 4 speed to 2004r , cost me 100 bucks
68 Long Fleet , ly6 , turbo 350 , 3-5 drop , original paint , front discs
67 Small window , 7 foot bed , tweaked 6.0 LSX 2004R Medium Olive
58 Apache fleet , 235 , offy intake , dual exhaust , 4 on the floor , red/white
69 Long Fleet , Custom , 6.0, 4l60 , AC , Medium Olive
67 chevelle is offline   Reply With Quote
Old 03-24-2016, 04:09 PM   #10
NC_John
NC_John's Avatar
When I put the tremec in my long bed I just had the driveshaft shortened and balanced. Also had these guys
http://www.driveshaftshop.com/
Put solid u-joints in it to make a bit stronger.
I doubt you are hooking up with 600 hp. Mine just spins, even with posi, so at least its easier on parts and I haven't broken anything yet.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 03-24-2016, 09:28 PM   #11
Tiger Joe
I've snapped a weak u joint in half on a hard 1-2 shift when the truck hooked. Blew the super T-10 apart twice too. I never broken the actual shaft even at 6500 rpm shifts so I think it will live on.
Two piece is shortened and already installed. Shop said there was slop between the two shafts which he fixed, so I should be good to go.
Old 03-25-2016, 06:42 AM   #12
NC_John
NC_John's Avatar
I remember the guy at the machine shop telling me the two-piece driveshaft was going to be the "fuse" in my setup. My transmission is way overbuilt for my current engine build (had it overbuilt to handle the next few engine stages) and the 12 bolt rear-end should be plenty strong. I have only 350 hp but ought not have any problems until I get some real tires out back instead of the skinny white-line radials.
1970 C-10 LWB "Blu"
Old 03-25-2016, 08:37 PM   #13
stsalvage
Scrapper 1
stsalvage's Avatar
I thought the new DOT law was nothing over 61 or 66 inches.Drive shaft places bare the responsibility if something goes wrong.And most Drive shaft places won't Do it.
You ever seen a drive shaft come undone under a truck i have 1977 1972 longhorn Pogo stick at 55 mph it was not pretty
stsalvage is offline   Reply With Quote
Old 03-25-2016, 08:57 PM   #14
Tiger Joe
Shop said 1 piece shaft was not an issue for the length I wanted in 3.5" aluminum. My issue was my clearance to my trailing arm crossmember.
Never heard of any law for driveshaft length. GM puts some pretty long driveshafts on some of the trucks from the factory nowadays.
