Old 03-24-2016, 10:00 AM   #1
T and S
T and S's Avatar
brake bleeder problem on 66'
Bleeding my brakes on the 66' (drums) . Rears done, moved to fronts, here's the problem. The bleeder screw is so close to the spindle C that you can not get a wrench on it. The wheel cylinders are NAPA brand, bleeders are metric (10 MM imagine that) Has anybody ran into this problem ?
If you don't like this pound sand .....
T and S is offline   Reply With Quote
Old 03-24-2016, 04:10 PM   #2
60-66
60-66's Avatar
Re: brake bleeder problem on 66'
Have you tried taking your old bleeder and putting it in the new cylinder ? I've done that before and it worked
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 03-24-2016, 05:25 PM   #3
T and S
T and S's Avatar
unfortunatly I don't have those any more. Do they make extra long bleeders ? I looked at NAPA's web site, but couldn't really tell if their is a differance in length.
Old 03-24-2016, 06:31 PM   #4
Metalaroundstone
I have had this problem before. I was able to use a 1/4" drive 10mm metric deep socket.
Metalaroundstone is offline   Reply With Quote
Old 03-25-2016, 10:36 AM   #5
Rolland
Same problem here and I didn't want to re-use my old rusty ones. Searched all the parts stores and the only one who had any was O Reilly's. H9401-2, pack of two for $3.59. They are identical to originals, about 1 1/2" overall length.
Worked great using a 10mm brake bleeder wrench!
Rolland is offline   Reply With Quote
Old 03-25-2016, 09:54 PM   #6
T and S
T and S's Avatar
Thanks Rolland - now if I can get mine out without taking everything apart. But it looks like the right side has a little more room than the left.
Old 03-27-2016, 03:48 PM   #7
Metalaroundstone
I ordered a set of these. Thanks for the tip.
Old 03-27-2016, 05:03 PM   #8
T and S
T and S's Avatar
I ended up ordering the russell speed bleeders from summit in the same size.
Old 04-14-2018, 09:02 PM   #9
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Do you remember the part number?
66 C20 Service Truck:
Old 04-17-2018, 10:05 AM   #10
Rich 5150 69
Rich 5150 69's Avatar
http://www.russellperformance.com/mc/speed-bleeders/
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 04-17-2018, 02:13 PM   #11
LostMy65
LostMy65's Avatar
Originally Posted by Rich 5150 69 View Post
Thank you
