Old 03-24-2016, 11:05 AM   #1
sherm6413
Anybody do an ls swap AND AAW classic update kit together?
If somebody has I have a couple questions about a couple wires, thanks
sherm6413 is offline   Reply With Quote
Old 03-24-2016, 01:12 PM   #2
beaterku
beaterku's Avatar
Re: Anybody do an ls swap AND AAW classic update kit together?
I am not doing them together, but I am installing the AAW kit now and the LS later this year.
beaterku is offline   Reply With Quote
Old 03-24-2016, 01:59 PM   #3
Oldblue68chevy
I just did a wire harness and an ls swap. it wasn't an aaw but it was a universal gm harness.
Oldblue68chevy is offline   Reply With Quote
Old 03-24-2016, 03:18 PM   #4
hozeman469
Up to my elbows in a ls swap like that right now,along with vintage air and Dakota digital dash,yeah I know crazy.Have wires everywhere.so don't know how much help I would be.
hozeman469 is offline   Reply With Quote
Old 03-24-2016, 06:10 PM   #5
Kennuck
Kennuck's Avatar
I have done it.
1970 Short Wide
5.3 4L60E BlackBear tune
3:73 gears, Boyd's Tank
2.5 / 4 drop 5 lug disc brakes
Vintage Air
18x8 Ridlers 255/55 frt. 18x9.5 275/60 rear
Kennuck is offline   Reply With Quote
Old 03-24-2016, 10:04 PM   #6
sherm6413
Here's my dilemma , I have intellitronix gauges goon in too, so that throws in a wrench. Where will my vss signal from Ecu hook on aaw harness?? Or go straight to gauges? Also there's a long unlabeled orange wire by heater wires ... Where does this go? Doesn't go to heater , and I've yet to get ahold of intellitronix or aaw customer service after 2 days of attempts all day...frustrating
Old 03-24-2016, 10:18 PM   #7
badherb
badherb's Avatar
great source:
http://lt1swap.com/2000harness.htm
1960 SWB “Pops”
If you won't support our troops then stand in front of them!
badherb is offline   Reply With Quote
Old 03-24-2016, 11:36 PM   #8
hozeman469
Looking at the aaw wire diagram a single orange wire will go to the cigarette lighter maybe that's it.VVS is set up different on mine but I would think it would go to the cluster not the aaw harness.
Old 03-25-2016, 12:02 AM   #9
clinebarger
Classic Update? Highway? Restoration partial?
clinebarger is offline   Reply With Quote
Old 03-25-2016, 08:51 AM   #10
Kennuck
Kennuck's Avatar
VSS signal wire goes directly to the speedo gauge it doesn't hook into the AAW harness.
The long orange wire is probably for the glove box light. There are other orange wires in the harness under the dash but I think they are labelled.
The instructions are quite good and are downloadable from the AAW website if you don't have the sheet that shows this long orange wire. I used AAW tech support a couple times and always got a person to talk to right away and answered my questions promptly. Good Luck with your build.
1970 Short Wide
Vintage Air
Old 03-31-2016, 11:30 AM   #11
sherm6413
Thanks guys, I have the papers and diagrams. Kennuck- so I don't use the included purple and yellow vss wires at all you say? I go from swap harness vss signal straight to gauge?
Old 04-01-2016, 09:59 AM   #12
Hart_Rod
Hart_Rod's Avatar
You don't use those 2 wires and can remove them from the harness. Use the vss wire from the EFI harness.
Hart_Rod is offline   Reply With Quote
Old 04-01-2016, 10:57 AM   #13
sherm6413
What do I do about a ground for the vss then?? Good info guys, thanks again
Old 04-01-2016, 01:06 PM   #14
Hart_Rod
Hart_Rod's Avatar
I think you are talking about the gauge? Just use a chassis ground.
Old 04-01-2016, 03:15 PM   #15
sherm6413
Ahh, ok thanks guys I will see how this goes tomorrow!!
