09-25-2003, 09:53 AM | #1 | |
Happy to be here
LOHRTBT-Inner fenders?
09-25-2003, 10:33 AM | #2 |
BeWarE tHe eViL CrAnkTOe!
Well.....If you have seen the engine bay in the Green/white Hills hotrods truck, That is exactly what I want to do. Its basically sheet metal going from the inner lip of the fender bolts to the edge of the framerail down by the headers. Have them slanted like that... Does that make sense? Then have them painted to match the theme of the truck. That way...I wont worry about the tires hitting the fenders. They had plenty of clearance with thiers and they were running 22's up front if I remember right.
I will need to relocate my things that are attached to the inner fenders of course which might be fun, but not too bad. Did you have another suggestion for me?
~Dave~ You can call me Mike, Mike Oxlong - 1986 Chevy SWB - Stock for now - 1986 Chevy Custom SWB *Stolen 6/26/05* - 1985 Chevy SWB SOLD - 1999 T/A Some mods www.cardomain.com/id/ramairdave AIM Screenname - Jester84 |
09-25-2003, 11:18 AM | #3 |
I thought the Hills truck had 20's up front, 22's out back?
09-25-2003, 11:21 AM | #4 |
could be..Anyone have a pic of the engine bay on it??
09-25-2003, 11:42 AM | #5 |
I do at home, but the quality may not be that good. I used a disposable camera and took the picture last year at Truckin' Nationals. Ill check tonight and try to post something.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
09-25-2003, 11:43 AM | #6 | |
Trucker.
09-25-2003, 11:45 AM | #7 |
dave, just out of curiousity, what is the "theme" for your truck?
09-25-2003, 11:56 AM | #8 |
Yup that is the truck....only not an engine shot!! DOH! Thanks Izzy!
I thought they were 22's My theme is the scallops Costanza!! lol
09-25-2003, 12:37 PM | #9 |
Thanks fiveeight, I wasn't 100% sure.
09-25-2003, 02:25 PM | #10 |
Finally!! here is a poor pic of what I am talking about.
09-25-2003, 03:09 PM | #11 | |
Trucker.
09-25-2003, 04:20 PM | #12 |
exactly!
09-25-2003, 07:26 PM | #13 |
Happy to be here
OK, now I know what you have in mind. I saw the truck at Dust Off, and wasn't very impressed with the fit of the panels. It doesn't look "bad", but I think it could look better, considering what he does for living.
I think it would look better if it came down from the fender lip, and rolled out, and down again. Either that, or shave the firewall, and bring another short piece down to meet the side pieces...
09-25-2003, 07:34 PM | #14 |
Under construction!
2001 Silverado bagged on 22's. *Sold* |
09-25-2003, 07:48 PM | #15 |
Happy to be here
Scoti,
I would have said 20/22 too. It does have 22's, but the tire stagger is so big that it appears to have 20's up front. I think the burghandy and white truck he built for a customer has 20/22's... |
09-25-2003, 07:50 PM | #16 | |
Trucker.
09-25-2003, 07:54 PM | #17 | |
Under construction!
That truck has 20's on all four corners.
09-25-2003, 08:22 PM | #18 | |
Happy to be here
09-25-2003, 08:25 PM | #19 | |
Happy to be here
You don't even want to know how I would (did) do it. I probably have more body work in my inner fenders, and liners than most guys have in their entire truck.... |
09-26-2003, 12:12 AM | #20 |
I think it has 22's all around.
We considered something like that for my 71. It just didn't work out because the top of the fender is a little lower than in a 73-87. It just would not have looked nearly as good as that truck.....take my word for it. Here is what my truck has now. I will admit I was a little unsure of the look but it is come together and has grown on me.
74 swb 71 2wd Jimmy 82 2wd Blazer |
09-26-2003, 12:13 AM | #21 |
This pic is with the hood on so it is a little dark.
09-26-2003, 12:46 AM | #22 |
Happy to be here
I am always drooling when you show pics of your truck. This first pic does look a little odd, but in the second pic, I can see it blends better.
I designed mine to clear with the standard X-member. Now I am considering a notched X-member, so they may get cut again. This shows how much mine are moved up, and it's probably still not enough... |
09-26-2003, 09:30 AM | #23 |
Under construction!
I plan on doing something similar to this on my truck.
One of the truck because it's sweet!
09-26-2003, 03:36 PM | #24 | |
Trucker.
09-26-2003, 09:32 PM | #25 | |
Happy to be here
If I can get it moved to Stoked Out Specialties shop, I think things will start to change quick.... |
