Old 03-24-2016, 06:07 PM   #1
lkfldredneck
No power to dash lights
Im not getting any power to my dash lights. i had power to one a while ago, it turned on and there was only one, so i replaced all of them. I want to start trouble shooting but im not sure where to start and what is involved. im pretty sure no fuses are gone, unless one went between the time. But any help in trouble shooting would be great.
lkfldredneck is offline   Reply With Quote
Old 03-24-2016, 06:09 PM   #2
lkfldredneck
Re: No power to dash lights
Also, its an 85 gmc k10
Old 03-24-2016, 06:12 PM   #3
chengny
chengny's Avatar
How about the heater/AC control panel? Does that have backlighting?
Recheck the fuse labeled INST LPS - top fuse 2nd column from the right (while looking forward).
Do you have a meter or test probe? If not, consider getting one.
chengny is offline   Reply With Quote
Old 03-24-2016, 06:38 PM   #4
lkfldredneck
I never checked the top fuses, just the ones i could see without breaking my back. turns out the one had a Car fuse in it (Newer style mini fuses)
I changed that fuse and that was problem. couldnt read what fuse it was but im guessing that inst lps fuse. thanks for the help though. cant believe it was that easy..
Old 03-24-2016, 08:31 PM   #5
franken
Is the headlight switch grounded?
Is the headlight switch knob turned all the way to the right?
franken is offline   Reply With Quote
Old 03-24-2016, 11:49 PM   #6
lkfldredneck
It was the fuse mentioned above. Thanks though. I may not be the smartest out there but the headlight switch was fully counterclockwise when i originally installed the lights
Old 03-25-2016, 08:57 AM   #7
Pontiac1976
Pontiac1976's Avatar
LoL This happen more then you thing to people, that do not know the years, or some time they or some one turn switch knob on them. And they start checking all kind of stuff with out staring to check the easy stuff first go down the line.
Good job on the fuse fix
1977 REG cab Long Bed with a 1984 Front Clip, 82 305 .60 over 9.0.1 flat top pistons, 4bbl, TH350, w/84 SS-intake & cam , w/ 1977 big block rad, 1975 gear box, 1984 master w/ metric fittings top & SAE fitting @ portion block, 1975 3.42 gear open diff. Duel 77-87 Factory air cleaner, duel inlet from rad support . Down sized 9' to new 8' Steel flat bed
Was a 77 454 w/308 gear. Taken out 550 lbs. up front with motor clip change.
Pontiac1976 is offline   Reply With Quote
