Master cylinder
Is there a dual m/c that I can directly use to replace the stock one in my '64 gmc? I am hoping for a direct bolt in without having to drill or cut extra holes. Thanks,
Fourdy |
Re: Master cylinder
I just put one in my 1964 panel. I used one from a 1967 4X4 with drum brakes. Bolts right in. A1 Cardone part number 10-1329.
Hope this helps. John P.S. this is for manual brakes. |
Re: Master cylinder
Thank you so much. Just ordered one.
60-66 Nut
![]() ![]() Join Date: Mar 2007
Re: Master cylinder
It doesn't have to be for a 4x4. One for a '67-'70 C series will work just fine.
Re: Master cylinder
you may have to adjust the push rod some, otherwise direct fit. Some guys say they don't have to adjust the rod, in my case my pedal goes all most 2-4 inches from the floor.
If you don't like this ![]() |
