Old 03-25-2016, 06:28 PM   #1
Cautrell05
Towing mirrors
I need to upgrade the motors on my 99 obs K2500. I'm looking at the standard manual pull out, power adjust style. From what I have found, there is at least 15 different options. Which ones are better and which ones should I stay away from? I also need to replace the heater control head. Is there and reason I couldn't install one for a Tahoe and use the rear defrost for the mirrors? Additional wiring required for that obviously.Thanks
Nick
Fast, Cheap, Reliable. You may pick two
My 47/S10 build http://67-72chevytrucks.com/vboard/s...d.php?t=679723
Cautrell05 is offline   Reply With Quote
Old 03-25-2016, 07:35 PM   #2
54 jimmy
54 jimmy's Avatar
Re: Towing mirrors
I bought mine off ebay for $175.00 mine are power mirrors with the manual pull out. non heated. I love them have not had one issue with them at all. way better than the sucky stock 97 mirrors that you could not see crap with. I will post some pics tomorrow of them extended the are in in this pic.
There is nothing you can't fix with a BFH or a FIRE WRENCH.
1997 chevy k1500 ext cab z71 (daily driver) sold
1996 chevy k1500 reg cab 4x4(daily driver)totaled
2008jeep patriot (wife's daily driver
2008 chevy 1500 ext cab 4x4 sold
2011 chevy 1500 crew cab ltz (daily driver)
1996 chevy 1500 reg cab 4x4 project sold
2006 pontiac grand prix gxp (daily work commuter)
54 jimmy is offline   Reply With Quote
Old 03-25-2016, 09:32 PM   #3
95 S_Trucker
95 S_Trucker's Avatar
Re: Towing mirrors
I got mine from 1a auto.
http://m.1aauto.com/mirror-pair/i/1a...=546513&y=1998
95 S_Trucker is offline   Reply With Quote
Old 03-26-2016, 01:14 AM   #4
95 S_Trucker
Re: Towing mirrors
Btw, the mirrors that are heated have a different connector. The wires are not present in the door. You would have to run wires from the rear defrost circuit(if your truck has one) through the dash and out to each door. If you don't have rear defrost, you would need to run a switch and relay. It's a lot of work just to have heated mirrors.
Old 03-26-2016, 12:23 PM   #5
Cautrell05
Re: Towing mirrors
I figured that I would need to run the wires out to the mirrors. That's not really a big deal. Like I said earlier, I already have to replace the heater control so that would take care of the switch and relay part.
