03-25-2016, 11:59 PM | #1 |
Post Whore
Rear sway bar for a 2wd Blazer
Hello, I have a 1981 full sized 2wd Blazer w/a shackle lowering in the rear (non flipped) is there a factory rear sway bar or an aftermarket unit that will work? Thank you.
03-26-2016, 09:59 AM | #2 |
I know the pieces fit
Re: Rear sway bar for a 2wd Blazer
There's a factory unit, I think it was available on 3/4 ton and 1 ton trucks only and they're somewhat rare. But beefy.
03-26-2016, 01:05 PM | #3 |
I think they only fit 14 bolt rear ends
03-31-2016, 01:16 PM | #4 |
03-31-2016, 05:59 PM | #5 |
Post Whore
Wild look to this unit. Thank-you.
05-18-2016, 03:49 PM | #6 |
I used a ford f250 (older like late 80s or 90s) got it dirt cheap (free). looks exactly like the picture but it goes around the bottom side of the diff. I did have to weld the brackets to the frame.
05-18-2016, 03:53 PM | #7 |
