Old 03-26-2016, 04:25 PM   #1
RANDY COX
RANDY COX's Avatar
hydraulic clutch conversion on a 64
has anyone did a hydraulic clutch conversion on their truck if so you do have info on where you got the parts, was it a kit or....this is on a 64 with the mechanical linkages I went with a big block and headers...the header tube is right in the way of the bar...maybe I need the right style headers for a manual trans...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 03-26-2016, 06:18 PM   #2
padresag
Re: hydraulic clutch conversion on a 64
capt fab's hydr master setup may work that he developed for the 60-62 s. you will just have to fab a mount for the slave.
ron
padresag is offline   Reply With Quote
Old 03-26-2016, 08:57 PM   #3
aotte1
Randy,
I have an original hydraulic clutch bell housing set up for 60 -66. Not sure if works for you/helps. It is the bell housing and lower slave cylinder/bracket.
Les
aotte1 is offline   Reply With Quote
Old 03-26-2016, 09:04 PM   #4
aotte1
Another photo
Old 03-26-2016, 09:10 PM   #5
padresag
Originally Posted by aotte1 View Post
Randy,
Les
Les; that would be from a 60-62? it would work but is not required for this as he doesn't have the clearance problems that the 60 -62 has on the drivers side.
there are people though looking for that setup for 60-62s frequently.
he just mainly needs to make a mounting bracket on the drivers side and modify his linkage rod to fit
ron
Old 03-26-2016, 09:12 PM   #6
markeb01
Senior Enthusiast
markeb01's Avatar
The setup I made up can be seen on page 2 of my build thread.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 03-26-2016, 09:39 PM   #7
RANDY COX
RANDY COX's Avatar
Thanks for your input guys, I went on ahead and just cut the header tube out of the way and going to try to reroute it,I got my z-bar mounted and am going to have to cut the lower arm off and move it over to be more inline with the rod to the fork...it's been worked on before I got the truck to...
1964 BBC 402 4x4
Old 03-26-2016, 10:52 PM   #8
aotte1
Ron,
Thanks, will save for somebody with 60-62 who needs one.
Thanks,
Les
Old 03-27-2016, 12:02 AM   #9
Captainfab
60-66 Nut
I make a hydraulic clutch conversion for the '63-'66's as well as the '60-'62 and '67-'72's. Here's the for sale thread for the '63-'66 kit.
http://www.67-72chevytrucks.com/vboa...d.php?t=651200
