Poly on my wood bed
What are you guys using to coat your wood bed after staining? I was told to use this stuff
![]() Thoughts?
Chris _______________________________ 1979 Chevy Stepside SPORT 2018 Chevy Silverado, 39 years apart ![]() My build 2008-2016. http://m.imgur.com/a/bURrE |
Re: Poly on my wood bed
Just bringing back up to get some feed back
I used something very similar we used 5 coats.
it took a day in between each coat |
Did you sand between coats?
yes I did with 220 grit sandpaper.
it looks like a boat very thick but If I wanted to I could put something in the back with out worrying about hurting the wood. Mind you nothing but a grill and chairs will ever be going in there. Tailgating at The New England Patriots games. |
Thanks. Do I have to drill the sides of the edge boards and the front of the boards by the cab? I have the main mounting holes predrilled.
Gentleman Jim Driver
Joe '75 GMC Gentleman Jim '84 Chev C10 Short Wide - Super duper plain (manual steering, manual brakes, no dome light, no cig lighter) '85 Chev C10 Short Wide - Super plain Vortec 4.8 4L60E trans also: '81 K30, '83 C30 Crew Dually, '84 M1028 CUCV, '85 M1009 CUCV, another '85 C10 SWB, '89 R3500 Flatbed |
"Thanks. Do I have to drill the sides of the edge boards and the front of the boards by the cab? I have the main mounting holes predrilled."
The angle strips are factory welded in with bolts welded in place. Everything I read said do not remove the Angle strips or bolts that are welded in place. So I etched out the bolt holes and slid the boards under the Angle strips |
Robert Olson Transport
![]() Join Date: Oct 2002
I used marine grade about 4 coats sanding in between
#10 | |
if my memory serves me correct we had to cut in 9 holes for only the 2 edge boards. this allowed the to slide under and the metal strips hold them down.
the strips not holding down the angle we bought bigger 2" Fender Washer stainless for even more support |
Chris
I drew up something very crude on my pc ( not to scale) The black lines represent holes cut in the wood. Circles represent the cut out for the bed to frame bolts. Now if you managed to remove the colts from the angle strips you will not have to slot the wood but would be able to drill it instead. Most of the time you ( even if you have bough a pre drilled kit) Will have to slot. I know someone that has built a few step sides and when we were milling the wood he said your going to need to slot the wood. We thought he was wrong in the end we had to. |
#13 |
Perfect. Thanks for the illustration. My bed is completly apart. I think I should be able to drill holes and not have to slot them. Thanks for all the help. Hoping to get it ready for install here in the next week or so
#14 |
How much poly should I need? Quart?
#15 |
I bought a Gallon and have about 1/2 left..
