Old 03-27-2016, 10:33 AM   #1
scott-wisc
scott-wisc's Avatar
C/20 to 5 bolt conversion
I'm starting my lowering project. I have a '71 C/20 LWB that when finished will have a 4/6 drop and 5 bolt wheels. I've decided to use a '77 Suburban as a donor. All the needed parts have been removed and the rest has been sent to the melting pot. I'm doing an A-arm swap as well as adding the donors power steering.
First question; Should I be paying any attention to the shims, either on the truck as I tear off the original suspension or from the donor?
scott-wisc is offline   Reply With Quote
Old 03-28-2016, 01:58 AM   #2
andrewmp6
Re: C/20 to 5 bolt conversion
I wouldn't worry about the shims tell i have to do a driveway alignment then drive it to a real alignment shop.
andrewmp6 is offline   Reply With Quote
Old 03-29-2016, 04:52 PM   #3
scott-wisc
scott-wisc's Avatar
It's looking like the control arm swap isn't going to work. The bottom shaft is wider and will hit the headers on the drivers side. I'll spend the extra cash and get the conversion spindles from ECE
Old 03-29-2016, 05:09 PM   #4
scott-wisc
scott-wisc's Avatar
Photo;
Old 03-30-2016, 02:00 AM   #5
andrewmp6
A little heat and dimple the header your fine on that.
Old 03-30-2016, 07:28 AM   #6
scott-wisc
scott-wisc's Avatar
The photo is of the 3/4 set up. The 1/2 ton a arm is at least an inch wider.
Old 03-30-2016, 11:06 AM   #7
chevy_mike
Never Ending Projects
chevy_mike's Avatar
If you can get a set of '63-'72 arms, they should be the same as your 3/4 ton ones, outside of the ball joint hole size. The '73 and later arms use rubber bushings and end up wider because of it.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
