03-27-2016, 07:11 PM | #1 |
How to clean exterior Evaporator Core
I'm asking...ha!......
Seems water, degreaser, a brush and blow dryer are the ticket, but I thought to ask before I do something I shouldn't. Thanks.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
03-27-2016, 08:56 PM | #2 |
Re: How to clean exterior Evaporator Core
That's one way to do it
03-27-2016, 11:42 PM | #3 |
GM has a really great evaporator dip cleaner we used for problem cars that was not only a cleaner but a anti-growth protective coating as well. Try you local dealer for more current information and what it would cost you.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
03-28-2016, 04:06 AM | #4 |
The first thing I do is use compressed air to blow out as much of the crap in between the fins as possible.
08-11-2017, 10:06 PM | #5 |
What's the best method of cleaning this? Trying to overhaul the A.C system and replace the heater core.
08-11-2017, 10:55 PM | #6 |
Post Whore
There are lots of coil cleaning products out there. Here is a list from Grainger.
https://www.grainger.com/category/co...leaner&sst=All
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
08-12-2017, 08:30 AM | #7 |
When I see an oily spot, like on the upper right corner of Lugnuts evaporator, I think "leak".
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
08-12-2017, 10:49 AM | #8 |
I've never really worked on an a.c. system before. It hasn't been hooked up since before I bought the truck. They even bypassed the heater core. I sure hope it's not a leak. All of your input is greatly appreciated.
08-12-2017, 05:24 PM | #9 |
It should flushed and pressure tested. I would not install an evaporator without pressure checking. I know some guys do take that risk but these evaps can look brand new from the outside and be corroded from the inside. Never know for sure until it's pressure tested
08-12-2017, 05:26 PM | #10 |
Also I'd remove the expansion valve to flush and pressure check
08-12-2017, 06:59 PM | #11 |
What type of shop can I get that done at?
08-12-2017, 07:59 PM | #12 |
