Old 03-28-2016, 12:38 PM   #1
Figuarus
Figuarus's Avatar
283 truck vs car block
Hey guys, I just came back from a trip to California, and brought back my brother's 283 from his 64 Impala wagon.
I want to rebuild it, but want to know a few things.
First, are there any differences between the truck and car blocks during that year on the 283's
Second, I was contemplating on swapping out my camelback heads onto the new block, but might just use the heads he already has installed. I dunno if this is a good idea, or if I should find another set of heads.
Eventually, the 283 in my truck will be overhauled and re-sealed due to various leaks and issues. I will need an engine in the interim since it's my daily driver.
Thoughts, ideas, criticism, etc?
2013 Malibu LTZ
1996 C1500 4.3/5spd 2wd
Figuarus is offline   Reply With Quote
Old 03-28-2016, 02:56 PM   #2
urmyboyblue
Re: 283 truck vs car block
A 283 is a 283- no differences despite the vehicle it came in. You might see a minor difference in heads or a 4 barrel vs a 2 barrel, but that is it. I would run whatever heads come on it. Not really worth changing heads unless there is an issue with the ones that are on it.
urmyboyblue is offline   Reply With Quote
Old 03-28-2016, 03:57 PM   #3
GRX
GRX's Avatar
Yep. No difference. Same casting numbers = same block.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 03-28-2016, 04:06 PM   #4
Figuarus
Figuarus's Avatar
Cool. just wanted to be sure. I'll pull the block number in a little while and figure out what I have.
2013 Malibu LTZ
Old 03-28-2016, 04:08 PM   #5
65chevysub
65chevysub's Avatar
What's a good way to beef up a relatively stock 283? I'd like more pep to pull my 65 Suburban around with my TH350.
65chevysub is offline   Reply With Quote
Old 03-28-2016, 04:14 PM   #6
Figuarus
Figuarus's Avatar
yep.
I have a different intake, a quadrajet, 192 camelback heads and headman headers. The block is still stock. I upgraded to HEI ignition.
It's not a huge HP gain, but I do notice a difference from what it was to what it is now.
Plus, running in this config, I manage to get very close to 14 mpg on the highway.
2013 Malibu LTZ
Old 03-28-2016, 04:36 PM   #7
par4tom
If you're going to go ahead and rebuild it, I'd go ahead and look at swapping out the factory cam for something that fits your needs a bit better. In the old days, they had "RV Cams" which gave a little lope at idle but were pretty well mannered out on the road.
There is nothing the matter with the double hump heads, but you will want to check the valve seats and see if they are OK for running unleaded pump gas.
If you do get into a rebuild of those heads, you may find it more cost effective to go with a newer-style aluminum head that flows a bit better then the old double humps and for about the same amount of money.
I went through this a couple of years back on a 350 and there is no one single answer other than what your budget will limit...
Bottom line is that you've got a pretty good tried-and-tested motor that should give you years of trouble-free service once you get it all dialed in.
Tom
PS - If you have a local machine shop, ask the guy there for his thoughts. I'm sure this is not his first 283 he's done...
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 03-28-2016, 07:55 PM   #8
LVPhotos
LVPhotos's Avatar
My 283 had no side engine mounts. Only the front horseshoe mount and manual bellhouse ones.
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 03-28-2016, 09:25 PM   #9
GRX
GRX's Avatar
'57 block - a pretty rare piece. 1958 was the first year for side mounts, and '57 was the first year for the 283. So it's a one year deal.
