Old 03-28-2016, 05:24 PM   #1
klwebb
1971 trailer light-turn signal
Hey y'all. I probably should have come here for advice first but oh well. My rear light harness is so jacked up. Everything in front of the rear gram crossmember seems fine, but everything from the tail lights to the crossmember plug has been spliced and cut so much it's ridiculous (by P.O) so I ordered a "trailer light harness" from Brothers that will plug into the harness at the crossmember and then I will be getting a 60" led light strip from autozone that serves as the brakes, running, and turn signal lights that will plug into the trailer harness. Any thoughts? I'm hoping this works. I will also be replacing the flashers and fuses, so everything is "fresh" in accounting w the blinkers.
18 year old girl who loves old trucks
•Previous Projects•
1971 c10 longbed 350/350
1977 Silverado longbed 350/350
1978 K10 shortbed 350/t400 lifted 6 inches on 33s
"LONGBED LIVES MATTER"
klwebb is offline   Reply With Quote
Old 03-28-2016, 06:21 PM   #2
Lowenuf
Lowenuf's Avatar
Re: 1971 trailer light-turn signal
as always, start checking grounds....... grounds play hell on trailer wiring issues
I had to install actual housing ground wires on the rear tail lights to get a good ground
Lowenuf is offline   Reply With Quote
Old 03-28-2016, 06:22 PM   #3
klwebb
Care to go into detail on how you did that? Pictures or diagrams?
•Previous Projects•
Old 03-28-2016, 07:02 PM   #4
Lowenuf
Lowenuf's Avatar
i drilled small holes into the removable inner pieces, used wire with eyelets on them..... joined the rear housing wires with the side marker housing ground wires, and self tapped screwed them into solid bed material....
Old 03-28-2016, 07:05 PM   #5
Lowenuf
Lowenuf's Avatar
usually an indicator of a bad ground is when a turn signal from one side is activated, and it flashes both sides, and then when you activate the opposite side, nothing flashes..
Old 03-28-2016, 08:39 PM   #6
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: 1971 trailer light-turn signal
If you get under the truck at the back drivers side about 2 feet from the bumper should be a connection. It's round. Inside the frame. This connection has all the wires from the cab in it. This is the only place they should come from. You can go to any good parts store and buy a trailer harness that pluggs into the plug and then plug your tail light plug into it and it will all work as it should.
Now to trouble shoot it take the plug apart and use a test light to check each wire that is coming from the cab. Have some one inside the cab put on the brakes and you touch each wire till you get the light.
Do this for everything, brakes, turn signales and running lights. It takes a little while but in the end you know what every wire is and does for you.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-28-2016, 09:22 PM   #7
VetteVet
Msgt USAF Ret
VetteVet's Avatar
Here is the harness for the truck.
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 03-29-2016, 02:31 PM   #8
snipescastle2
snipescastle2's Avatar
Talking Re: 1971 trailer light-turn signal
I found a tail light rear harness from a 1973 to 1987 square body truck is almost indenticle to the ones on our trucks, but the lamp sockets are just a little different. If you find a decent one in a salvage yard, you only need to change (splice) the older style plugs onto that harness and your'e good to go. The main plug that it attaches to has the same connector on it as well! I think I paid $15 at pick n pull for mine.
Good luck!
Ben
"Persistence is the twin sister of Excellence.one is a matter of quality,the other, a matter of time"
“Serious Black” my 1971 Short Bed Fleetside Sold to
an outstanding man in Lees Summit,Mo. “Gone, but by no means,Forgotten”
snipescastle2 is offline   Reply With Quote
Old 03-29-2016, 07:41 PM   #9
swamp rat
swamp rat's Avatar
Don't mess with that LED strip until you get all your lights working
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-30-2016, 08:29 AM   #10
snipescastle2
I agree on waiting until you get the wiring sorted out first before the LED's. You will have to splice those in just as you would stock lamps any way, more work in my opinion than you need.besides, you need to apply your budget where it's needed, instead of "Flashy" bling stuff... Kinda sounding like my stepfather, sorry...I have refurbished so many parts on my truck, no telling how much money I saved, if I couldn't salvage what I had, or find a good used part, then I spent the money on new or reproduction stuff. Besides, nothing fits better than original GM parts the General made! Now, I'm lucky as I have many resources at my disposal, where most people do not, that made my build so much easier.
If you know anyone with a decent air compressor and find a cheap sand blaster, even the cheap harbor freight siphon (Place the suction hose in a bucket) that will help you prepare a lot of small parts.
Ben
Old 03-30-2016, 10:56 AM   #11
klwebb
I think everyone is confused. I'm looking to have the LED strip be my turn signals, because a $50 strip is cheaper than a $150 replacement rear harness. Eventually I'll go back to stock look but right now money is tight and I need blinkers
•Previous Projects•
Old 03-30-2016, 01:33 PM   #12
Andy4639
Old member
Andy4639's Avatar
Not confused: That's why I said get under the truck and find which wire is which. Then you can run the wires as needed.
Until you know which wire is which you can't do anything.
You could even take the round connection a part and the side that goes to the rear and cut the leads about 6" a way from it and tie your light bar into it. It will have the factory plug seal then. You will need to find the right wire for the right effect of the bar.
Old 03-30-2016, 03:56 PM   #13
snipescastle2
Unhappy Re: 1971 trailer light-turn signal
Well,
I tried to steer you in a cheaper direction by modifying a '73 to '87 Chevy truck rear tail light harness from your local pick your part, probably $10-$15 and all you would have to do is splice in your lamp sockets....but, you can do as you wish, it's your truck.
Ben
Old 03-30-2016, 04:00 PM   #14
klwebb
I'm not for sure doing anything guys! If I can find a 73-87 harness I'll definitely do that but I've been unable to find a pick a part close enough to me! I appreciate all the input
•Previous Projects•
Old 03-30-2016, 07:40 PM   #15
swamp rat
swamp rat's Avatar
If it was me i would probably cut the wires as far from the plug as possible and before the tail lights where all the wire is still good and just splice in new wires and add or clean grounds where necessary. That would get rid of all the damaged wires. Follow the schematic, use shrink wrap, i prefer solder over crimp connectors.
Mike.
72 3/4T 4X4
4" BDS Lift
33" BFG's
