Old 03-28-2016, 05:52 PM   #1
craigg1
Removing fenders
I need to remove my fenders so I can clean them up some. Is it possible to remove just the fenders without having to also remove the inner fenders/wheel wells? Also, are the fenders fairly easy to remove? Thanks.
craigg1 is offline   Reply With Quote
Old 03-28-2016, 06:15 PM   #2
mark 68
Re: Removing fenders
Just got done doing this to a 1968 c10, but I removed the whole thing at once (wheel well and fender). There is @ 20 bolts per fender to remove the whole thing. Ask away if you got questions.
mark 68 is offline   Reply With Quote
Old 03-28-2016, 06:45 PM   #3
hugger6933
The thing about leaving the inner on the truck is the J nuts that the inner is attached with will break and you need the fender inner combo on a table [or stand ] to reach in there with vice grips to hold the broken part of the clip. I've never removed a inner from a fender where at least a couple of those not break. Good luck
hugger6933 is offline   Reply With Quote
Old 03-28-2016, 07:26 PM   #4
craigg1
Was it pretty easy removing the fender and wheel well together?
Old 03-29-2016, 09:47 PM   #5
swamp rat
swamp rat's Avatar
I was able to soak the inner J nuts and all of them with PB Blaster for a couple days then slowly work them out by backing out a little then back in and another spray of blaster, back them out again, but yea its pretty easy just more weight.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
