Old 03-28-2016, 07:01 PM   #1
JMD
JMD's Avatar
Name that part
Took apart my '67 k20 3 years ago and of course didn't label anything. Figured "I'll remember" Can anyone tell me what I'm looking at here?
My build thread: http://67-72chevytrucks.com/vboard/s...96#post7439296
JMD is offline   Reply With Quote
Old 03-28-2016, 07:09 PM   #2
hugger6933
Re: Name that part
Clutch bell crank bracket. It goes on the frame under the general area of where the master cylinder would be.
hugger6933 is offline   Reply With Quote
Old 03-29-2016, 10:12 AM   #3
JMD
JMD's Avatar
Re: Name that part
Thank you sir, must have come off a different frame as my '67 is an auto. No wonder I couldn't figure out what it was.
Old 03-29-2016, 11:49 AM   #4
burnin oil
Re: Name that part
I didn't think a 4x4 auto was available till the end of the body style.
burnin oil is offline   Reply With Quote
Old 03-29-2016, 07:19 PM   #5
Grumpy old man
Grumpy old man's Avatar
Actually the picture makes it look bigger than it is , it's a jack mount that's located behind the seat on the passengers side it's only about 3 inches wide
Grumpy old man is offline   Reply With Quote
Old 03-29-2016, 07:50 PM   #6
swamp rat
swamp rat's Avatar
Re: Name that part
Looks like a fancy bottle opener on one side
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-29-2016, 08:30 PM   #7
irl104
Re: Name that part
Yes, Holds the jack handle crank and lug wrench. The little cut out is where the retainer spring connects.
irl104 is offline   Reply With Quote
Old 04-01-2016, 10:57 AM   #8
JMD
JMD's Avatar
Re: Name that part
Thanks guys, much appreciated.
Can anyone else verify this? My truck has traded hands countless times and it could very well have come with a manual trans from the factory. SPID says it had a 327, but makes no mention of an auto trans...There's no evidence of clutch linkage on the cab, so unless the PO went through the trouble of removing all the extra hardware I'm led to believe it came with an automatic. Thoughts?
Old 04-01-2016, 11:44 AM   #9
chewychevy67
Re: Name that part
Yep jack part. I think only 67 68 cause 69 went to the bag in the cab corner style.
chewychevy67 is offline   Reply With Quote
Old 04-01-2016, 01:13 PM   #10
leddzepp
Moderator
leddzepp's Avatar
Re: Name that part
This ^^^
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
