Old 03-28-2016, 08:09 PM   #1
Nodnarb76
Nodnarb76's Avatar
Brake booster vacuum hose question
In the middle of swapping a 2004 LQ4 into my 87 Suburban, I have realized the nipple on the back of the intake manifold is a different diameter than the nipple comming off my brake booster.
Assuming I'm not the first person to run into this, was wondering what the solution is?
1987 R20 Suburban LQ4/4L80e swap: http://67-72chevytrucks.com/vboard/s...d.php?t=693824
Nodnarb76 is offline   Reply With Quote
Old 03-28-2016, 08:51 PM   #2
jessemthompson
Re: Brake booster vacuum hose question
Take a look at GM Part # 12559760. Its the adapter I used on the swap in my 72.
jessemthompson is offline   Reply With Quote
Old 03-28-2016, 09:20 PM   #3
Nodnarb76
Nodnarb76's Avatar
That looks like the same nipple I have on my manifold already. The brake booster hose is too small to fit over the end. Fists on the smaller nipple on the booster just fine.
Appreciate the help though🙂
Old 03-28-2016, 09:45 PM   #4
foamypirate
foamypirate's Avatar
OEM LS booster vacuum hose worked perfectly for me. That might be an option.
foamypirate is offline   Reply With Quote
Old 03-28-2016, 09:51 PM   #5
Robznob11
Robznob11's Avatar
I went to orilyes and bought a 90* rubber elbow in the help section then used an crossover adapter barb. Made for a clean install
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 03-28-2016, 10:37 PM   #6
Nodnarb76
Nodnarb76's Avatar
That's a great idea! Going to o Riley's tomorrow!
Old 03-28-2016, 10:42 PM   #7
Robznob11
Robznob11's Avatar
Yea not sure if it was a pvc elbow or what. Kinda looks like a spark plug boot. It's in bubble wrap. You should find it easy. Just look around....
LED TAILS
Old 03-28-2016, 10:49 PM   #8
Nodnarb76
Nodnarb76's Avatar
