Old 03-28-2016, 08:30 PM   #1
Andy4639
Old member
Andy4639's Avatar
Question Annoying brakes
I had to replace the CCP proportioning valve last weekend while at the beach car show. The CCP proportioning valve had the plunger in the front of it with a rubber boot covering it. It blew the seal out of it and every time I stepped on the brakes it would shoot fluid out of it. I bought a new one and it doesn' have the front plunger. So any way here is the question for all of you.
The master cylinder is a after market one that I have no idea who makes it. I bought it used from a truck club member about 1.5 years ago. The problem is the lid moves around on it and the rubber gasket has about a 1/8" gap all around it. It leaks every time I drive it.
Tonight I hope I fixed it. I cut a piece of rubber gasket I had bigger than the lid so that it would over lay the master cylinder lip and with the lid in place it smashes it down good and tight. You can see the gasket in the pictures. I hope this has fixed it but wanted to hear what any of ya'll have done for this problem. If you have solved it by some other means please post them.
If this works I will take it back off and trim the gasket back to the edge.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-29-2016, 07:24 AM   #2
68panelman
68panelman's Avatar
Re: Annoying brakes
My 67 did this when I first got it. MC was new and I could not figure what was wrong. I "adjusted" the two hold down loops by pulling them sideways to have a tighter download on the cap. It did the trick. Worth a try Andy
68panelman is offline   Reply With Quote
Old 03-29-2016, 07:27 AM   #3
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: Annoying brakes
I will see if I can get it any tighter. I drove it to work this morning so I'll see if it leaks any when I get home tonight.
Old 03-29-2016, 09:53 AM   #4
72MARIO
72MARIO's Avatar
Re: Annoying brakes
The cover looks to small for the master cylinder. Are you sure its the correct cover ?
1968 Suburban numbers matching all original truck now equipped with 6.0/4L80 on Accuair
http://67-72chevytrucks.com/vboard/s...d.php?t=625017
1967 C/20 6.0/4L80 Roofing Truck
1990 V2500 Suburban "Plow Truck"
2005 TAHOE DD
72MARIO is offline   Reply With Quote
Old 03-29-2016, 10:36 AM   #5
Custom 68
Custom 68's Avatar
Re: Annoying brakes
I ended up buying a new "plastic" one and solved my issues. There are some nice aftermarket ones. CPP has one but I know you wont purchase from them, it is adjustable on all sorts of stuff.
http://www.classicperform.com/NewPro...V-1/MCPV-1.htm
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 03-29-2016, 11:14 AM   #6
Andy4639
Old member
Andy4639's Avatar
Lightbulb Re: Annoying brakes
I bought it all together but that don't mean much! It's just the opposite though! With just the supplied gasket the lid will move all over the place on it. It's pretty sold right now but I don't know how long it will hold up.
Old 03-29-2016, 01:09 PM   #7
67ChevyRedneck
67ChevyRedneck's Avatar
Re: Annoying brakes
Stop breaking your truck!
My mustang can't tow you in June
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 03-29-2016, 02:32 PM   #8
Andy4639
Old member
Andy4639's Avatar
Don't worry I have Hagerties it want have too!
Old 03-29-2016, 07:37 PM   #9
swamp rat
swamp rat's Avatar
Re: Annoying brakes
I bought a replacement when i did my brakes that had that problem, the upper surface was faced down too far and the lid would not sit tight in the gasket, i returned it back to NAPA and got a free replacement.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 03-29-2016, 07:55 PM   #10
Andy4639
Old member
Andy4639's Avatar
Drove the truck to work this morning and back home. Checked it out when I got home. No sign of leakage so hope I'm good.
swamp rat,
didn't buy anything from parts store. I bought everything form a friend almost 2 years ago. I did buy the new gasket but it was from a car show vendor. I may ride down to his shop in a couple of weeks to pick up a chrome 11" booster though. he told me if it didn't fix it to bring it back and he would give me my $5.00 back.
