03-29-2016, 11:02 AM | #1 |
The mother of all stupid questions! Ignition switch hole?
Hey guys! I got a build going over on the "pre 47" side but it's kind of slow over there. So I figured I would ask here. I am in the process of installing the ignition switch into the dash and I need to drill the hole.
Question is do I need to make the hole with the one side straight to keep the mechanism from spinning in the dash when I key the unit? If so how the hell do I make the hole? If I just drill a regular hole will the tightened nut be enough to keep the mechanism from spinning? I have never seen a drill bit with one flat side. Heres a pic of the switch I got from American Autowire........... [/URL] |
03-29-2016, 11:07 AM | #2 |
Re: The mother of all stupid questions! Ignition switch hole?
Drill the hole and spot weld in a piece if flat stock on one side?
1959 Chevy Short Fleetside w/ 74 4WD drive train (current project) OrrieG Build Thread 1964 Chevelle Malibu w/ 355-350TH (daily driver) Helpful AD and TF Manual Site Old Car Manual Project |
03-29-2016, 11:14 AM | #3 |
Yep
03-29-2016, 11:14 AM | #4 |
Or drill a smaller hole to start and carefully carve it out to fit with a die grinder and a small diameter bur.
03-29-2016, 11:46 AM | #5 |
What a pain in the @$%#!!!! Is there a better (different) switch I can buy? Maybe I'' just go and buy a half million dollar stamping machine and spend another 75K on the right size die.
03-29-2016, 01:10 PM | #6 |
Try a file.... it's alot cheaper....
This really is a stupid question.... joking!
My Build: 57 Chevy Pro-Street |
03-29-2016, 02:42 PM | #7 | |
It's just that after spending 5 years working on something that you never wanted to do in the first place you get kind of burned out dink dorking with stupid $%&@ like this. |
03-29-2016, 08:14 PM | #8 |
I would just drill the correct size hole and tighten it down good, worked good for me on my '46.
Rob
My '47 C.O.E build |
03-29-2016, 08:28 PM | #9 |
Turns out the local hardware store had the $500,000 dollar stamping machine and Home depot had the $75,000 die.
[/URL] [/URL] |
03-29-2016, 08:54 PM | #10 |
Well done...that looks great.
1957 3100 1950 5 window |
03-29-2016, 08:58 PM | #11 |
Nice job...I was thinking old school star washer..
03-30-2016, 11:48 AM | #12 | |
How'd you do that?????
03-30-2016, 04:42 PM | #13 |
I'd say he drilled a smaller hole and did some very neat and tidy work with a couple of files or a dremal tool. Dang nice work no matter how he did it and that switch will never turn in the hole like all too many do in round
04-02-2016, 08:07 PM | #14 |
file it under patience
http://http://67-72chevytrucks.com/v...d.php?t=489721 |
