Old 03-29-2016, 11:58 AM   #1
70's luvr
Caught between a axle flip and a hard place.
1970 C20. I did an axle flip on the rear but am hitting the frame rail on some bumps. I have the original 5 leaf spring pack in the back and I don't want to do a C-notch (at least one that takes 1/2 the frame rail away) so how do I get another inch or two back into the rear suspension height?
70's luvr is offline   Reply With Quote
Old 03-29-2016, 03:50 PM   #2
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Re: Caught between a axle flip and a hard place.
I don't recall if the rear shackles on these are tension or compression style (I have only had trailing arm setups). Depending on the style, either a longer or shorter shackle will raise it up. Keep in mind that you only get half the lift of how much the shackle moves the mounting location (i.e. if the mounting holes are spaced 2" further apart then stock, you will only get a 1" lift).
Obviously this will raise the back of the truck. If you want to keep the current look, you'll have to notch the frame.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 03-31-2016, 12:17 PM   #3
70's luvr
Thanks for the reply Mike. I don't believe I could make the shackles any shorter than stock. I was wondering if a new set of leaf springs would buy me any height (Stock ones have to have sagged) but then it'll ride even stiffer. Do they make lift shackle mounts? Can you just move the stock ones down?
Old 03-31-2016, 12:24 PM   #4
lolife99
67-72 parts collector,…
lolife99's Avatar
Have you thought about adding an air-lift style bag set-up on the rear.
Two bags could be plumbed with Schrader valves for easy height adjustments?
Keith
Convert to disc brakes.
Old 03-31-2016, 03:14 PM   #5
chevy_mike
chevy_mike's Avatar
I know on my '84 M1010 (basically a K-30 with ambulance box) they were shackle flips for doing a lift. I did mine with a 2 1/2" lift. No idea if they make them for '72 and earlier.
Old 03-31-2016, 09:08 PM   #6
chase@ridetech
chase@ridetech's Avatar
you can try an AirOver Leaf, but it will also stiffen up the ride quality.
Chase Mundy
Direct Line: (812) 481-4736
Email: chase@ridetech.com
chase@ridetech is offline   Reply With Quote
Old 03-31-2016, 09:13 PM   #7
chase@ridetech
or... if you dont mind welding, you could build a small notch out of steel tubing. I grabbed this image from another site:
Chase Mundy
Old 04-01-2016, 08:12 AM   #8
ksshane
ksshane's Avatar
I had the same problem. ended up doing a c notch. New springs will help some, but you will still probably hit from time to time.
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 04-01-2016, 01:37 PM   #9
70's luvr
Thanks for ideas! Say I wanted to lower the spring mounts? Could you just use 1/4 plate to extend down from the frame then bolt the mount to it? In this case one set of bolts would go through frame and lower bolts would go through mount then plate.
Old 04-01-2016, 02:12 PM   #10
70's luvr
Looks like they make 4" flip shackles that I assume really means 2" of actual lift? I'm guessing you use the stock shackles and just flipping them over.
http://www.offroaddesign.com/catalog/shacklekit.htm
Edit: Just spoke to Chris at ORD and it's 8" lift so actual would be 4"...too much.
Old 04-01-2016, 02:24 PM   #11
tinydb84
tinydb84's Avatar
I like how low it is in the rear. Any reason you don't want do to the C notch like Chase suggested? That is what I would do personally.
My (1975) C20 had support brackets off the bottom of the shackles and hanger mounts as they hung partly below the frame. It was basically an L shaped bracket that was riveted to the frame and bracket. You could lower your shackles and hangers and do the same if you want.
David
Instagram: myfabguy
Old 04-01-2016, 02:31 PM   #12
70's luvr
I guess I still wanted to keep some of the C20 capacity. I put just my dirt bike in the back and I'm banging the frame too easily. A heavy duty C-notch will probably end up being the outcome of this.
Old 04-01-2016, 03:28 PM   #13
tinydb84
tinydb84's Avatar
If you only need an inch or so I wouldn't worry about notching it (done properly of course).
Depending on your budget you can also get new/lift springs.
David
Instagram: myfabguy
